Author Topic: Suzuki PE250 T or X exhaust  (Read 9473 times)
maxvmx
« on: October 08, 2017, 03:10:27 pm »
Looking for a PE exhaust pipe - anyone?
Offline Glen08
Re: Suzuki PE250 T or X exhaust
« Reply #1 on: October 09, 2017, 02:01:03 pm »
GMC concepts..!
« Reply #2 on: October 09, 2017, 09:12:17 pm »
i know where there is one but its on a scoot...might be able to organise a "model" for a replica if your desperate.
« Reply #3 on: October 09, 2017, 10:34:46 pm »
I have jigged this model now;
« Reply #4 on: October 09, 2017, 10:49:51 pm »
That looks great. 80T, 81X, 82Z are all the same. That pipe will also fit the 80/81 RS250 if you want to market that towards the US/Can guys too, so 5 models all up.
« Last Edit: October 09, 2017, 10:53:39 pm by LWC82PE »
« Reply #5 on: October 09, 2017, 11:01:05 pm »
Thanks for that info Leith
Is the muffler the same on the RS model too?
« Reply #6 on: October 10, 2017, 08:10:48 am »
problem solved ;)
« Reply #7 on: October 10, 2017, 08:47:58 am »
Mufflers are the same part numbers for all 3 PE and the the RS. 80 models use a different muffler bracket/hanger  compared to  81 and 82 but this does not affect the actual muffler. They kept that the same. The part number for the RS pipe is different to PE. It may be just something slightly minor different with the tuning of it or the baffles/mesh inside the pipe compared to PE or the mount under the tank could be in a slightly different position like the 79-80 RM. I know some guys used your RM250 pipe on the PE and all they had to do was alter/shift the mount under the tank a bit. If an RS owner was to buy the PE pipe i would perhaps sell it with the mount not under the tank attached and supply it for DIY fitment just in case. It could be the same location as the PE or it might not. The RS frame and engine starts off as essentially the same as the 79/80 RM250 and the 80 PE250, The shape/bends etc of the pipe wont be an issue. So there is no major differences that would stop this pipe going on an RS.
Here is an 80 model brochure pic.
« Last Edit: October 10, 2017, 08:51:46 am by LWC82PE »
Offline Oldfart
« Reply #8 on: October 10, 2017, 03:36:32 pm »
Same pipe should fit the Rm 250 T
« Reply #9 on: October 11, 2017, 11:03:29 am »
Yes  I was going to suggest you might be chasing a stock pipe.
Sorry for the hijack
Offline rocketfrog
« Reply #10 on: October 13, 2017, 11:03:22 am »
I have a good RM250T Pipe, stock. It has a little tweak up near the manifold joint but he body of the pipe is VGC. PM me if you like, I am in QLD.
« Reply #11 on: October 13, 2017, 05:54:44 pm »
I got a RM250T pipe (not for sale) but from memory the mount under tank was a bit different and needs shifting for it to bolt directly onto the PE. Also the stinger end is a bit different. Nothing major. The reason i got it was to make it fit on a PE. Its just that its not a 5min bolt on and away you go. Weighs a lot less than the PE pipe too.
« Last Edit: October 13, 2017, 09:11:33 pm by LWC82PE »
