Author Topic: Dual rate monoshock?????  (Read 4102 times)
Offline Grunter215
« on: August 29, 2008, 09:54:40 pm »
I got this shock with YZ250H which has two springs on it (seems standard  plus a small one about 3inch). Shock body has extra grooves for spring seat and a nylon type spacer/retainer between springs. There is also   "C P" stamped on body.All looks professionally done. Was there a dual spring kit available or is this someone's experiment. Any theories on this.Will do pics soon as.
Offline yzhilly
  • Melbourne
Re: Dual rate monoshock?????
« Reply #1 on: August 29, 2008, 11:35:17 pm »
The IT shocks had 2 springs but i think the travel lengths were different ???
Viper #436
« Reply #2 on: August 30, 2008, 03:45:33 pm »
I think alot of people would change the the standard progresive wound spring on the "h" models for and earlier model Dual rate springs, I have a Gaythorne yamaha one (Qld) done back in the day, also read a T&T article about as well a while ago. Gave a better ride apparently.
YSS
« Reply #3 on: August 30, 2008, 03:50:25 pm »
Combining the dual spring with a good piston and better shim stack it should be a good working shock
« Reply #4 on: August 30, 2008, 05:06:15 pm »
Why was the dual rate springs prefered over the progressive wound ones?
YSS
« Reply #5 on: August 30, 2008, 05:21:55 pm »
Because you can change rates
Offline Grunter215
« Reply #6 on: August 30, 2008, 06:53:24 pm »
Here's some photos.Have been told its a S&W kit.Anyone know about this kit???
Offline Grunter215
« Reply #7 on: August 30, 2008, 06:56:26 pm »
Another pic
Offline Grunter215
« Reply #8 on: August 30, 2008, 07:01:47 pm »
The main spring seems to a standard progressive one from my comparison to other springs.
Offline TonyB
« Reply #9 on: August 30, 2008, 08:34:27 pm »
All I need for my 465 monoshock is a dual rate spring setup just like these. so can anyone point me to one of these? I think it is what Yamaha really needed. or maybe there is a sp[ring manufacturer that someone knows?
'Life's Journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways,totally worn out, shouting,  ' Holy sh!t... What a Ride!! ' '
YSS
« Reply #10 on: August 30, 2008, 09:04:23 pm »
YSS, min order 100 pieces
