Clubroom
Tech Talk
PE 175T Crank rebuild.
Topic: PE 175T Crank rebuild. (Read 3399 times)
Scriberman
Novice
October 05, 2017, 07:05:14 am »
Pe 175 T. Just about to rebuild my crank and the new crankpin is hollow from one end with a oil hole drilled to feed the big end brg. Recommendations on what side to fit the pin from and orientation of the oil hole?? Thanks.
TT5 Matt
Re: PE 175T Crank rebuild.
October 05, 2017, 10:09:34 am »
I'd say you have a ts/er185 rod kit which have oil feed bigend bearing but since pe's are premix the oil hole can go any position.good thing about little pe's is once you have runout of 175 o/size pistons you can use ts185 pistons
Clubroom
Tech Talk
