Author Topic: Yamaha DT 322 article  (Read 24932 times)
« on: October 04, 2017, 12:23:47 am »
4 pages plus 1 from Webco
And a bit from the 1974 Webco catalogue
« Last Edit: October 09, 2017, 07:01:05 pm by LWC82PE »
Offline YUMASTEPSIDE
Re: Yamaha DT 322 article
« Reply #1 on: October 04, 2017, 05:45:32 am »
......interesting Leith, I have copies of the same thing, but the Suzuki version. With the Suzuki you have to use the '69-'70 model otherwise there is not enough meat in the cases. A standard RT1 360 piston works but nowdays you have to make your own sleeve.
           Roger
« Reply #2 on: October 04, 2017, 05:51:00 am »
.....oops! just noticed the Suzuki thread above this......sorry to repeat myself....
                  Roger
Offline yamayeeha
« Reply #3 on: October 07, 2017, 08:13:38 am »
Is anyone having problems seeing the images above?
My screen just shows a ? where the image should be.
Any input appreciated.
thanks
« Reply #4 on: October 07, 2017, 09:03:43 am »
I don't know why it does that. I have not changed anything. Its so annoying. Why have the links changed? I will try fix it.
Actually, no they are showing now and i did not touch anything. They are large images so i think you just need to wait and allow time for them to load if you have got slow/bad internet.
« Last Edit: October 07, 2017, 09:10:26 am by LWC82PE »
Offline OverTheHill
« Reply #5 on: October 07, 2017, 08:18:12 pm »
No image here, on google chrome. Not sure what your talking about but if it's turning a 250 into a 360 [322] i have something 'like that' as am running a 250 crank in 360 hence i go by RT325 on the 'Vintage Yamaha Enduro' site https://yamaha-enduros.com/ . love to see the article. Took 6mm of the top of the cylinder & it ends up with about 180 exhaust duration. Was years ago but still run it once in a while. needs more comp to compensate for the short stroke but never bothered. is an RT2 cylinder but same horse realy bar the reed. In fact i'm using an RT1 piston & just cut put it at bdc & felt penned the inlet square onro the piston & cut it out. Must remember that next time i go pulling wheelies down the road as at the time i though jeez i shouldn't have cut it out 'that big' lol. If i'm on the wrong track with the story then sorry about that.
Offline OverTheHill
« Reply #6 on: October 07, 2017, 08:28:59 pm »
Actualy come to think--i have another one--a DT1MX motor with a 360 crank whatever that makes--about 280  or summit. That's in an R5 twin frame--.
« Reply #7 on: October 07, 2017, 09:31:40 pm »
I can see the images and i am on Chrome. If no one else can see them but me then i may need to change the folder settings that they are in but as far as i know they are in a public folder.
I just logged out and i could still view the photos on here. As far as i can see there are no problems with my hosting, especially if some other people can see them? If only some people cant see them then i do not really know what the issue could be but it must be something on your end i would think.
Send me an message if you are still having trouble and i'm sure i am not the only one who can see the images and i will look into it more if needed. I am pretty sure all the permissions are set correct at the moment they may not be.
« Last Edit: October 07, 2017, 10:18:18 pm by LWC82PE »
Offline OverTheHill
« Reply #8 on: October 07, 2017, 10:27:41 pm »
yep still nothing except empty big areas where each pic or article should be so tried firefox & got nothing, not even the empty spot. Don't worry & thanks for--um, whatever you're doing your end. All good. I'll keep looking now & then incase it turns up. Sounds very interesting.
« Reply #9 on: October 08, 2017, 02:30:06 am »
I can email it to you but it would be good if it can be made viewable to everyone on here. Probably something to do with the crap NBN i bet. I could try re-sizing them smaller and see if that helps as they are quite large in size.
« Last Edit: October 09, 2017, 06:48:06 pm by LWC82PE »
« Reply #10 on: October 08, 2017, 10:18:27 am »
If you are using Firefox try updating the browser. That may fix it.
« Reply #11 on: October 08, 2017, 04:14:04 pm »
Nothing here either , Google windows 10 .
« Reply #12 on: October 08, 2017, 04:27:04 pm »
I think i know what is going pn but i just dont know how to fix it yet
OZVMX with firefox, not logged in and not logged into Onedrive - i cant see any pics
OZVMX with firefox logged in and not logged in into Onedrive - cant see any pics
OZVMX with firefox logged in and logged into Ondrive- i CAN see the pics
At the moment i can not see any more settings i can change though. Everything is all set to 'shared' and 'public' there is another thing i may do which may work though.
Offline OverTheHill
« Reply #13 on: October 08, 2017, 08:21:32 pm »
Very last link works thanks. Was there anymore info in the other links or just the same thing tried different?. Others links initially said sign into your microsoft account so signed up allowing link to work but just blank. No worries & appreciate your trying to sort it [or was the last sorted link it in total total?], be great if they still existed!!. Well i sort of cheated & made my own in a different way but anyway!!. Thanks again.
« Reply #14 on: October 08, 2017, 09:04:56 pm »
There should be 4 pages plus a snippet from the webco catalogue
So only the last link (webco one) worked for you? None of the article pages? i spent several hrs trying to sort this out today and i need a break from it :)
