Author Topic: New forge photos  (Read 4462 times)
Offline FAT-TOY
New forge photos
« on: September 10, 2017, 08:44:34 pm »
  This is a photo of the Forge on it's stand. You can see the acetylene regulator I fitted, the BBQ type reg restricted the gas flow to much to the home made burner which goes into the top of the forge.
 https://imagizer.imageshack.us/v2/311x233q90/r/924/cm1Zmf.jpg
  In this photo you can see the position of the Hebel blocks and the fire bricks that make up the floor.
https://imagizer.imageshack.us/v2/311x233q90/r/923/pyC8lo.jpg
 This is the view from the back and it shows the insulated door which when open allows me to put longer length steel through if I need to heat it in the centre and when closed helps retain the heat.
https://imagizer.imageshack.us/v2/311x233q90/r/924/r2gyp4.jpg
 The next 2 photos show the Forge with the front sliding doors in open and closed position. The sliding doors allow me to close them,  just leaving room for access to the heat.
https://imagizer.imageshack.us/v2/311x233q90/r/922/DPDVNK.jpg
https://imagizer.imageshack.us/v2/311x233q90/r/922/OCpQGw.jpg
These last 2 photos show my home made anvil and heavy stand, in the 2nd photo you can see the Hardy hole plus the 12mm round hole.
https://imagizer.imageshack.us/v2/311x233q90/r/922/CQW2C3.jpg
https://imagizer.imageshack.us/v2/311x233q90/r/922/ptP5p1.jpg
« Last Edit: September 10, 2017, 09:05:45 pm by FAT-TOY »
Everyday I find one more name to add to the list of people who piss me off.
Re: New forge photos
« Reply #1 on: September 10, 2017, 09:21:30 pm »
That's very good Zane ;)where do you get Hegel blocks from?
Offline FAT-TOY
« Reply #2 on: September 11, 2017, 07:42:33 pm »
  I got mine from Saddingtons.  They always have damaged blocks in stock and you can pick them up very cheap or even free if your lucks in.
        Zane
« Reply #3 on: September 11, 2017, 09:25:52 pm »
here ya go
Offline FAT-TOY
« Reply #4 on: September 11, 2017, 09:48:44 pm »
  Thanks Alan, I won't ask how you did that but it has made a hell of a difference.
            Zane
Offline fred99999au
« Reply #5 on: September 13, 2017, 05:06:35 am »
Thanks Hoony for the webmagic bit and thanks fat-toy for the photos.
