Clubroom
Tech Talk
6 Volt 2-Pin flasher relay for LED's
Topic: 6 Volt 2-Pin flasher relay for LED's (Read 4718 times)
cyclegod
Sunny PERTH W.A
August 24, 2017, 05:20:22 pm »
Can anyone direct me where to get a 6 Volt 2-Pin flasher relay which works with LED replacement bulbs. Have tried these 2 but both are no go for flashing
http://www.ebay.com.au/itm/Electronical-LED-flasher-relay-for-universal-use-on-6-Volt-bikes-motorcycles-6V-/360558335764?hash=item53f2f39714:m:mfHMYa-oI9ijJnbQu-ebBCA
http://www.ebay.com.au/itm/BIKINGEAR-MOTORCYCLE-UNIVERSAL-6-12v-VOLT-LED-INDICATOR-FLASHER-RELAY-NEW-HOT-/192287262411?hash=item2cc536c6cb:g:CrkAAOSwQTVV8i9Z
The last one only works on 12v bikes, the first one lights up but won't flash.
Ban BLACK rims NOW
LWC82PE
Superstar
Re: 6 Volt 2-Pin flasher relay for LED's
August 24, 2017, 05:54:27 pm »
6v for LED might be a hard one. Have you looked in the MCS catalogue? Or maybe try
http://www.norbsa02.freeuk.com/
because he specializes in 6v & LED stuff
DR500
B-Grade
August 24, 2017, 06:36:06 pm »
put a resistor in to increase load, then should turn on/off
TT5 Matt
August 25, 2017, 08:25:42 pm »
Those electronic relays should work without resistors as there just a on/off switch on a timer
Clubroom
Tech Talk
