Author Topic: Fork refinishing  (Read 5678 times)
Offline John Smith
Fork refinishing
« on: August 14, 2017, 12:55:15 pm »
Hey all,
Whats the best way to get lower fork legs back to new look? Ive got an 81 RM and their not too bad, a few scratches and a couple of deeper gouges. How do i get these out?
I want the factory finish again.
Tks
JS
Re: Fork refinishing
« Reply #1 on: August 14, 2017, 07:38:03 pm »
My version of deep gouge is probably different than your version. is it flailing around and bleeding lots or just a flesh wound?.  Probably wont get the deep ones out  as they are already.. well. out.. What you can do is use different grades of good old wet and dry paper going with the grain and just take your time  till you get an even finish. its going to take more than a few minutes like hours and hours to get to a decent stage . when you have that done, use one of those green scotchbrite pads to put the factory finish back on.
Offline alexbrown64
« Reply #2 on: August 14, 2017, 08:40:29 pm »
Sometimes there is like a clear coat on the legs that comes off with paint stripper. Then you can hit them with a very light gauge flap wheel or wire wheel. The you can polish them up to a near mirror finish with a buff wheel and that white bar stuff. From there I am not sure on how to get the legs back to factory, but I imagine like pokey said with the scotch brite pad.
Can they then be clear powder coated, or just rattle can clear coated?
Offline rocketfrog
« Reply #3 on: August 15, 2017, 04:33:31 pm »
There are many ways to get there. Here is my method - Strip the fork and blend out the deepest gouges (10-20 thou) with a flap wheel (Al Oxide) or preferably a die grinder with a scotchbrite wheel/Disc. Start with brown (coarse) and go easy as It will remove material quickly, go with red if the gouges are less tan 10 thou and work down to blue for 5 thou and under. Take off the material surrounding the deepest part of the gouge/scratch to achieve a generous blend ratio usually about 20:1. That means for a 10 thou gouge, the blend width should be approx .200 inch, or until the damage is feathered out to the desired aesthetic standard for the part. You get the picture?
You can achieve the same results manually using various grades of Al Ox wet and dry, files to remove raised metal etc, it is safer if your not confident with air tools, plus it is cheap but will just take a little longer.
The OEM finish on most KYB/SHOWAs is a uniform brushed finish with a radial brush pattern and then clear coated.
To achieve this, I turn the lower on my lathe whilst holding a small hand held pneumatic linisher with a scotchbrite belt fitted against the fork lower turning at low RPM. I start with a blue belt to get a uniform finish over the entire leg including the previously blended damage.
Don't worry, you can get a good result by working manually if you buy a scotchbrite belt designed for a linishing machine and use it like a strap in a see sawing motion. Hold the lower in a soft jawed vice or get a second person to hold the leg whilst you work along the length with the belt (the helper would turn the leg slowly as you go).
At this point it will be obvious if there are any more areas which require rework to achieve a uniform finish, so repeat the blending in local spots as required and then repeat the turning.
The areas around the axle boss and cable keeper mounts are hand finished with green scotchy, as you cannot travel through this area using the linisher. Carefully work in the same radial direction and avoid cross hatching.
Mask/plug the internal bore to prevent chemical ingress. Clean wipe with solvent such as prepwash, etch with 10% SODIUM HYDROXIDE (mild caustic soda solution) - fresh water rinse - neutralise with acetic acid (vinegar)- fresh water rinse-then dry.
Use POR15 or similar poly clear coat designed to cover bare metal to restore the environmental barrier.
Hints- avoid using silica carbide wet and dry use Al Ox instead as silica carbide can become embedded in the aluminium and a dissimilar metal corrosion attack can result.
POR15 recommends the use of a POR Etcher designed to work with their system and while it is expensive it can save time and the use of the other chemicals I have mentioned.
Avoid using steel wire wheels as they are very aggressive and can leave steel embedded in the soft alloys. Sometimes brass bristled brushes can be handy to remove stubborn soiling.
A highly polished finish can be achieved if you work hard at getting all the scratches and pitting out, otherwise you will only highlight every small defect. Brushing is a little more forgiving and is more like the factory finish.
Offline John Smith
« Reply #4 on: August 15, 2017, 06:43:42 pm »
Thanks for the detailed information!
