Author Topic: 76 kx rod kit  (Read 6448 times)
Offline piney
76 kx rod kit
« on: August 07, 2017, 07:53:15 am »
Anyone know or recomend where i can get a rod kit for a 76 kx250
    Cheers Piney
Offline k2000x
Re: 76 kx rod kit
« Reply #1 on: August 07, 2017, 09:28:15 pm »
Same right through to 07
Offline William Doe
Re: 76 kx rod kit
« Reply #2 on: August 10, 2017, 10:39:50 am »
No there not
, this happens a lot with KX parts. You will see parts listed to cover 74 to 79 but thats not the case, its a nasty trap for young players, just about every part site i look at other than OEM have parts listed incorrectly 125 and 250  ::)
74 to 76 rod is the same and so is KT 250
78 to 07 is the same, you can use a later rod but need a spacer under the cylinder. Theres a bloke over here sells laser cut spacers to suit if you cant find a rod .
Offline piney
Re: 76 kx rod kit
« Reply #3 on: August 21, 2017, 04:51:42 pm »
Thanks for the heads up  WD
Me thinks its same guy i bought my 76 Kx400 rod kit off.
It is an 500 rod with lazer cut spacer .
« Last Edit: August 21, 2017, 04:59:26 pm by piney »
