Author Topic: clutch side engine cover82 wr 250  (Read 8395 times)
Offline shortshifter
  • Sunshine Coast QLD
« on: July 29, 2017, 12:53:38 pm »
I think I'm going insane with this sometimes it tightens down sometimes it just won't like now.The pin on the right side of the cover seems to be catching on the gear shift mechanism???Does that pin serve any purpose?Can it be shortened?
Re: clutch side engine cover82 wr 250
« Reply #1 on: July 31, 2017, 07:33:25 pm »
how is the roller bearing in the kicker well lining up? is your gear lever slot lined up properly? are you getting it on square?? are the case locating pegs ok?
Offline smalls717
« Reply #2 on: August 01, 2017, 11:10:09 am »
apart from the spring ends sitting in the correct locations is the spring sitting correctly over the ratchet pawl?
if it isn't the kickstarter mechanism doesn't line up correctly.
« Reply #3 on: August 01, 2017, 05:19:37 pm »
get on to cafe husky and search the left kickers forum, lots of pics and how to fixes on there
« Reply #4 on: August 02, 2017, 12:08:29 pm »
thanks guys will look at all these suggestions. :)
