Author Topic: YZ125T Frame section  (Read 2581 times)
Offline rocketfrog
« on: July 26, 2017, 12:04:10 pm »
Does any one have a donor frame they would cut a section from for a repair?
The rear subframe has been cut to make a removeable strut similar to the 89 onwards YZ's. But it is a bad job and the owner would like to return to the stock configuration.
I am not sure if it is the RH or LH side which is required as yet, but if there is a willing donor it will save a lot of work.
Thanks in advance.
