Author Topic: 1979 or 1980 RM125 parts  (Read 5920 times)
Offline justanothercgrader
« on: July 22, 2017, 03:13:17 pm »
Hello,
I am looking for 1979 0r 1980 RM125 parts,
In particular a rear wheel, rear axle and adjusters, spacers.
Please call or Text Mark on 0417306023
Offline rocketfrog
Re: 1979 or 1980 RM125 parts
« Reply #1 on: July 26, 2017, 12:08:32 pm »
1979 1980 and 1981 RM100's use the same rear wheel. The axle adjusters and spacers are different. I have a set of Buchanon Stainless spokes (new) and a new aftermarket rim if that is a start?
« Reply #2 on: July 26, 2017, 08:59:54 pm »
Hi Rocket,
I will keep it in mind, although finding a hub is still the issue, and thanks i can now see that the RM100's wheel is similar except the Rim is 1.85 rather than the 125's rim of 2.15, what width is your rim?
There is a couple of wheels on evil bay USA except they both have slight damage to the inner brake drum area.
I would not have thought that they would be so scarce.
Thanks Mark.
Offline rocketfrog
« Reply #3 on: July 27, 2017, 11:18:04 am »
125 Rim is also 1.85
Offline rocketfrog
« Reply #4 on: July 27, 2017, 11:20:53 am »
Broken Sprocket lugs make them scarce as well. Could you clean up the drum with a skim on the lathe?
« Reply #5 on: July 27, 2017, 04:18:32 pm »
Thanks Rocket,
1.85 it is.
Both the USA wheel's i am looking at have the casting damaged, the internal ring / seal that meshes up with a similar ring on the brake
backing plate, this stops water getting onto the brake pads.
I know it's not a big deal, its just if i am going to spend $250 i thought i could get a damage free hub.
I have also today found one in Australia $260  :'(  Rusty spokes, do you know anyone with spokes…..
Regards Mark
Offline rocketfrog
« Reply #6 on: July 28, 2017, 06:43:36 am »
I have a new set of Buchanon Stainless spokes for 79 80 RM125 that I will sell for $100.
Offline rocketfrog
« Reply #7 on: July 28, 2017, 12:33:21 pm »
Various places will manufacture individual spokes if you only require a few. Usually they are supplied with a new nipple for around $3 each.
« Reply #8 on: August 23, 2017, 09:08:18 pm »
Bump,
Still looking for an 1979/ 1980 RM125 or 1979 to 1981 RM100 Rear wheel or hub please.
