Honda
M2 1976 CR250 timing URGENT!!
Topic: M2 1976 CR250 timing URGENT!! (Read 12671 times)
bazza
July 09, 2017, 11:34:07 am »
Thanks mike
Also is M2 1976 timing 1.5mm BTDC ?
Last Edit: July 18, 2017, 03:14:18 pm by bazza
sleepy
Re: M1 CR250 Points gap and timing
July 11, 2017, 06:36:56 pm »
Only got a manual for the "M" model but it has the timing at 1.5mm and the points 12 to 20. Points gap is not critical on something like that, just set the points then do timing.
bazza
Re: M2 1976 CR250 timing URGENT!!
July 18, 2017, 03:15:19 pm »
urgent please
80-85 husky
July 18, 2017, 09:36:34 pm »
see if you can get hold of macka McKenzie, he knows the elsinores inside out. i think he is gold coast motorcycles???
Tony.Brown
B-Grade
July 20, 2017, 03:37:13 pm »
Well I'll be buggered, I had no idea that was Wayne!
jimg1au
July 20, 2017, 09:03:38 pm »
if its the same as the 73/74 all you need is a set of feeler gauges and a cigerette paper
the timing mark should be on the plate aline the two pointers as the paper is pulled out of the points ie just opening
thats how i used to do it
jim
Honda
