Author Topic: How to case harden mild steel?  (Read 24220 times)
« on: June 18, 2017, 11:56:02 am »
Hey Guy's :-)
l have extended my footpegs but have only done it with mild steel, l guess it will wear away quite quickly? Is there an easy process to case harden my pegs?
I remember at school we heated metal red hot and dropped it in old motor-oil, is this a proposition or some other way to do it?
Regards, John.
Offline yamaico
Re: How to case harden mild steel?
« Reply #1 on: June 18, 2017, 12:17:34 pm »
In my experience that's the way to do it John, aside from buying a hardening powder. Heating red and the quenching in oil will work well, but you might want to temper it afterwards to remove the brittleness - just heat it up slowly to around 400F and cool it slowly in air, or if you do it in an oven, just turn the oven off with it still inside - best to do this when your wife/girlfriend (or both) are not at home though.
« Reply #2 on: June 18, 2017, 02:21:02 pm »
Ha ha, thanks. Yep will use the oven once the Missus goes to work :-)
Offline sleepy
« Reply #3 on: June 18, 2017, 04:04:26 pm »
If it is mild steel the oil quench will do next to nothing. The only way is to introduce carbon into the steel while red hot, the old blacksmith forge can achieve it but red hot into oil is not effective unless you start with a high carbon/alloy steel.
« Reply #4 on: June 18, 2017, 04:20:44 pm »
Do l have any options?
Offline sleepy
« Reply #5 on: June 18, 2017, 05:04:31 pm »
You could weld the edge with a hard facing rod or build it up with stellite. The speedway boys used to weld the bottom of the steel shoes with stellite. I have a little bit here that I got for an engine shop that used it to build up camshaft lobes. There are heat treatment powders available or you could send them to a heat treaters.
A quick search found this stuff . http://www.brownells.com/gunsmith-tools-supplies/metal-prep-coloring/color-case-hardening/surface-hardening-compound-prod27119.aspx
You could also track down a local blacksmith how could do it in there forge.
« Reply #6 on: June 18, 2017, 06:28:59 pm »
Thankyou. Would you do the same process to gears, or if they have been undercut?
Offline Momus
« Reply #7 on: June 18, 2017, 09:13:02 pm »
Ring me up if you do another set and I'll send you some 4130 chrome moly this stuff hardens well with an oil quench. Gears are made from a workhorse grade of case hadening alloy steel often 8620. This stuff is usually case hardened to a under a mm or so on gears so they usually do need re doing after undercutting. Proper processing would have the gears annealed and reworked.
If you love it, lube it.
Offline Tomas
« Reply #8 on: June 19, 2017, 12:42:18 am »
Induction hardening is used on gears in mass production. It is complex process and correct current must be used to achive desired penetration and correct hardness.
When you undercut dogs on your gears you only removing material from the face of each dog. There is minimal loss of strength when each dog is shortened by 0.5-1.0mm. Also removing material from face does not affect hardness of the rest of each dog.
Rehardening is not necessary.
You can undercut hardened gear dogs on a mill with high speed head using carbide end mills and carbide burrs of suitable shapes and diameters. Lots of setting up and measuring is needed to get this right.
For your foot pegs 4130-4140 is a good choice. After welding is done I would just heat up wear areas with oxy and bang it in some oil. You do not want to harden whole foot peg.
Offline sleepy
« Reply #9 on: June 19, 2017, 09:58:23 am »
No gears are not from mild steel, they are made from special steels designed for case hardening.
Getting gears re-hardened is a very risky process. The case hardening make the metal grow and distort and in a lot of cases I've seen they do not fit onto the shafts anymore making them useless.
Most of the wear on gear dogs happen on the top edge and no matter how far it is machined or ground back that edge always stays hard. The trick is to grind it back without softening it, if the dogs are straight it is easy to do with the correct shape grinding wheels and an indexing head.
« Reply #10 on: June 19, 2017, 11:01:34 am »
That is exactly where my education has me too Sleepy....well done
« Reply #11 on: June 19, 2017, 12:50:48 pm »
Thanks heaps Guy's, l think it is fantastic the knowledge that is shared here, love it ! :-)
« Reply #12 on: June 19, 2017, 01:18:39 pm »
Hey Guy's :-)
Regards, John.
Lay down some nickel bronze on it that is very hard be lucky to file it.
Machined from solid gears don't move much as the sintered OEM gears.
Offline djr
« Reply #13 on: June 19, 2017, 06:38:28 pm »
Is it really necessary to case harden extended foot pegs ?
I have fitted ready-made mild steel extensions to foot pegs on a couple of bikes , and the only problem I have had is the new extensions wearing away the rubber soles of my boots a lot quicker.
I must be doing something wrong ?
just saying
Offline fred99999au
« Reply #14 on: June 19, 2017, 10:46:39 pm »
Perhaps apply Nickel Bronze rods to the soles of your boots?
immutable force meets immovable object
