Author Topic: Pre90 RMX250 which years eligible?  (Read 13628 times)
Offline DJPresto
« on: June 04, 2017, 12:43:43 pm »
What years of the RMX250 can be raced in Pre90? Thanks
Triumph Speed Triple 1050, Husky XC430 1982, Husky WR240 1985, GSX1100ez, Husky CR250 1975
Re: Pre90 RMX250 which years eligible?
« Reply #1 on: June 04, 2017, 01:05:02 pm »
1989 model can.
Offline DJPresto
« Reply #2 on: June 04, 2017, 03:04:45 pm »
1989 model can.
Yep thanks. However I'm assuming that the RMX didn't really change much in the years following 89 so which models qualify?
Offline PEZBerq
  • Brisbane
« Reply #3 on: June 04, 2017, 08:09:29 pm »
1989 only unless you have written evidence to submit to MA to apply for a follow on year to be made eligible due to lack of model changes. Don't expect anyone has bothered to do this with an enduro bike for VMX yet. Perhaps your local club will be sympathetic. Good luck.
« Reply #4 on: June 05, 2017, 11:31:36 am »
90+ models have a 2-piece clutch cover among a bunch of other internal changes. This isn't an issue in itself, but I believe you cannot fit an 89 clutch cover to a later motor, so any 90+ motor stands out.
That said, the changes aren't huge, so you could probably make an argument that they are an eligible carry-over part.
Forks changed every year, and changed significantly in 91 or 92. Easily spotted by the steps in the upper tube between the triples.
Aussie delivered 94 & 95 RMXes got the upspec jap model, based on the 93-95 RM. These are easily identified by the radiator shrouds that cover the fuel tank. They are definitely not carry over bikes.
The yanks only ever got the same basic bike from 1989 to 96. The 96 got right way up forks.
Australia got the old/yank spec bike in 1996.
The last two points confused the hell out of me until I figured it out.
« Reply #5 on: June 05, 2017, 01:23:14 pm »
There was a JDM version with oil injection too.
Offline DJPresto
« Reply #6 on: June 22, 2017, 04:34:04 pm »
Thanks Nathan
