Author Topic: 1979 KX250 engine, cylinder, carby and exhaust  (Read 3158 times)
Offline bishboy
  • Toowoomba
« on: May 28, 2017, 09:12:39 am »
I have a KX250 A5 engine, a second cylinder, carby, exhaust and muffler for sale.
The engine has apparently been rebuilt recently to some extent but I have not taken it apart to check, I've only taken the head off to take some pictures.
It turns over easily and goes through all the gears.
It has some damage to the front engine mount area, but that could be welded up or ground flat and a spacer used?
There is also a bit of damage to the front sprocket guard mounting hole area, but the thread is not damaged.
The second cylinder looks ok.
The carby looks ok, no cracks or broken bits and is complete with slide spring etc.
The exhaust is pretty good, with some small dints.
I’m looking for $850 for the whole lot, although if someone wants a particular item let me know.   Pick up in Highfields (Toowoomba) or I can ship to wherever you are at your cost.
I also have a KLX frame, tank, seat, airbox and a few other bits if someone is interested.
If anybody wants pictures of anything in particular, let me know and I can send them to you.
