Author Topic: Rear hub difference RM250A/B/C  (Read 3999 times)
Offline micko
« on: May 03, 2017, 09:44:58 pm »
Apart from bearing sizes is there a difference, are they all magnesium ?
Re: Rear hub difference RM250A/B/C
« Reply #1 on: May 03, 2017, 10:16:02 pm »
They are all aluminium as shipped on the bikes from factory. There were optional magnesium rear hubs for the 76 and for the 77/78
To convert the 76 hub to use 17mm axle use bearings  KOYO DG1742RSC3 - 17X42X13  (they are only available with a seal on one side)
To convert 77/78 hub to 15mm axle use bearings  SKF 361202 15x40x11 with a 2mm shim or machine out the hub to use the stock 76 bearings which are 6302   15X42X13
« Last Edit: May 03, 2017, 10:49:25 pm by LWC82PE »
Offline micko
« Reply #2 on: May 04, 2017, 02:57:03 pm »
Thanks for the info
Offline 211
« Reply #3 on: May 04, 2017, 03:38:30 pm »
some of the very first RM A series used the left over RH/RN parts bin and I have seen a few with the tel tail 400000 part number sand cast into the hub (inside)
keep your eyes out for that one
