Author Topic: Open pipe on a 4 stroke ?  (Read 27757 times)
Offline jimson
  • Sanctuary point N.S.W
« on: March 31, 2017, 08:17:20 pm »
G'day viewers, I'm just after some information on running a 4stroke bike With an open exhaust pipe no muffler. Does this create valve & carbie problems ? Thanks Jimson
Offline mick25
  • Hunter valley NSW
Re: Open pipe on a 4 stroke ?
« Reply #1 on: March 31, 2017, 08:42:47 pm »
TT500 / XT500 seem to come alive with no Mufflers down low that is .
And sound great that's how they got there Nic name THUMPER .
Offline Oldfart
« Reply #2 on: March 31, 2017, 09:21:12 pm »
They require a tuned length of around 28 inches with a little bit of back pressure.
« Reply #3 on: March 31, 2017, 09:31:01 pm »
I think the "you will burn the valves if you take off the muffler " was a furphy to keep mufflers on
« Reply #4 on: April 01, 2017, 08:43:11 am »
speedway bikes ran for years with no mufflers yes its is a tuned length will not damage your motor one little bit
you need to tune it properly
Offline Daryl Jones
    • Old Bike World
« Reply #5 on: April 01, 2017, 10:17:37 am »
Depends on the Revs.   At 11,000rpm  20" is nearer to ideal.
I use a drilled metal cone for a baffle, area of drilled holes is greater than pipe end.
Gives something for the machine examiner to tick the box as an "effective muffler".
cheers, Daryl.
Life's too short not to try to do Everything.
"First they tell you you're wrong, and they can prove it.
Then they tell you you're right, but it's not important.
Then they tell you it is important, but they knew it all along."
Charles Kettering.
Offline Oldfart
« Reply #6 on: April 01, 2017, 11:36:37 am »
An old method was to paint the pipe and were the paint stopped burning was close to tuned length.
Offline Flipper
« Reply #7 on: April 01, 2017, 04:33:47 pm »
I was told by a pretty competent tuner back in the 80's that it was 'look for the heat ring', then 'cut 1 inch beyond that' for the perfect tuned length. Stainless pipes worked well, as the was a very obvious blue/yellow ring where the exhaust gases collected.
Offline sleepy
« Reply #8 on: April 01, 2017, 07:11:21 pm »
In the 70's when single Hondas where being palyed with, changing the muffler to something more "flowing" generaly required the carb to be richened and some found out if they didn't make thing a little richer the exhaust valve sometimes burnt. With retunning to suit it works fine if you can stand the noise.
Ask Mr Google about organ theory and exhaust pipes. A lot of research was done with books written on the subjects back in the 60's and 70's.
« Reply #9 on: April 02, 2017, 10:43:47 pm »
Pops Yoshimura tuned length for high comp SL125.
Other versions SL125
Oh the prices for the racing crank and close ratio gear sets....
« Last Edit: April 06, 2017, 06:08:20 pm by Tim754 »
Offline jimson
« Reply #10 on: April 04, 2017, 08:49:48 pm »
Thanks for your input everyone, I'm trying to get my Honda 350 twin to run right with open pipes. I need to jet the carbbies right & work out if the pipe should be baffled to create some back pressure. Jimson
« Reply #11 on: April 04, 2017, 09:22:09 pm »
what about your ears??
Offline fred99999au
« Reply #12 on: April 05, 2017, 08:46:38 am »
Pardon??
« Reply #13 on: April 05, 2017, 12:19:44 pm »
whaaat??
Offline fred99999au
« Reply #14 on: April 06, 2017, 07:55:53 am »
I SAID PARDON?!!!
