Author Topic: TM250K gear oil drain plug  (Read 7103 times)
Offline YZAT252
« on: March 16, 2017, 12:35:56 pm »
Does anyone know which of the two plugs is the drain plug? One in the middle facing straight down, or the one at the front on an angle?
Offline Doc
Re: TM250K gear oil drain plug
« Reply #1 on: March 16, 2017, 03:07:26 pm »
The rear one that faces straight up  ;)
Offline YZAT252
« Reply #2 on: March 16, 2017, 05:56:15 pm »
Thanks Doc, I have been given a couple of different answers, the old owner said the one at the front has a spring and cam so I figured it was the rear one. Cheers
Offline Ken 737
« Reply #3 on: March 17, 2017, 11:00:09 am »
Hi Craig. I never used the rear one, just the one with the cam and spring inside.
Ken
Suzuki fan - TM and RM
Love my IT too ????
Offline yamaico
« Reply #4 on: March 17, 2017, 03:17:51 pm »
Ken
Ken, that's the neutral detent holding pin, which you risk losing when removing to drain the oil. The drain plug is the straight one, as Doc says, and is at the lowest point of the gearbox.
Pete.
Offline Ken 737
« Reply #5 on: March 17, 2017, 04:22:36 pm »
Thanks Pete.
Ken
Love my IT too ????
Offline YZAT252
« Reply #6 on: March 17, 2017, 05:23:37 pm »
Thanks all for your help, I drained the oil today using the rear one, appreciate everyones advice. Craig
« Reply #7 on: March 17, 2017, 06:19:48 pm »
don't forget to put more in!! 8)
