Author Topic: RH into RM frame conversion?  (Read 10688 times)
« on: March 14, 2017, 01:10:19 pm »
I know anything can be done , but how hard would it be to place a 75 RH motor into a 77 RM frame/roller? Are they both side port etc?
Re: RH into RM frame conversion?
« Reply #1 on: March 14, 2017, 04:22:25 pm »
72 ts cases were the same as rm125S cases... good chance, only changed the cases into RM 125 B
« Reply #2 on: March 14, 2017, 06:09:04 pm »
RH is a 250. RA is a 125. I think we are talking 250's here?
Offline Oldfart
« Reply #3 on: March 14, 2017, 08:52:32 pm »
What year frame are thinking of using ?? Rm  76-77
« Reply #4 on: March 14, 2017, 09:42:39 pm »
right... :(
« Reply #5 on: March 15, 2017, 04:52:03 pm »
I would use 77 frame with probably the 125 forks
Offline William Doe
« Reply #6 on: March 16, 2017, 07:01:31 am »
I gotta ask Mick why ? an RM 250B motor is i would have thought a better option in every way .
An RH motor into a pre 75 frame i get, a 74 KX 250 frame would be a good option or even a custom frame, Cheney copy or the like ?
I got  an RM 250B motor with no home  :) its apart but all there if your interested .
Bill
« Reply #7 on: March 17, 2017, 05:46:19 pm »
I think if it makes use of spare parts you have then go ahead. May depend on intended use, do you want to even race it, or do you just want a fun and unique bike to build?
« Reply #8 on: March 18, 2017, 03:57:54 pm »
The few rides I have on a RH impressed me with the motor, I believed it was close to mid 80's power and out put.
Would others think the 77 RM motor is better?
Offline bazza
« Reply #9 on: March 18, 2017, 04:51:08 pm »
When i rode DT's RN (earlier model) was impressed how much power it had down low.
Embrace patina
Offline Oldfart
« Reply #10 on: March 19, 2017, 10:07:51 am »
you would be better sourcing a Rm 250 A (1976 ) package .... the A motor is very close in power delivery to a Rh 250.
The Rh frames were made of very thin wall chrome moly tubing ( imperial )  linked together with a super light one of  sand castings
in magnesium and Ali  and ended up with one hell of a light bike.
Very few of these parts carried on over to production models.
Offline gt96
« Reply #11 on: March 19, 2017, 07:42:42 pm »
I think you are spot on. First time I rode a 74 RH was 76 and I had an RM250A at the time. The RH engine was so much better that I wanted to swap it out at the time. The droopy TM slippery footpegs were rather distracting on the RH, but that engine was something else.
Recently, I have ridden fresh 74 and 75 RH's. The engines were pretty much identical and apart from the softer rear end on the 75, they handled very similar. Power and power type still leaves my RM250B for dead, and my B is not exactly slow.
Getting an up pipe built to match the original RH may be a little challenge.....
Good luck with the project and hope to see it out at some of the club events.
Offline Doc
« Reply #12 on: March 19, 2017, 07:57:02 pm »
I concur, DT's RN had power to burn in a package weight of a TM125. A bike I could easilly live with :)
