Author Topic: RM Clutch  (Read 7815 times)
Offline steve7406
RM Clutch
« on: February 20, 2017, 06:02:11 pm »
I just replaced the clutch fibre and steel plates clutch springs and cable now the clutch is very stiff what could I have done wrong
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Re: RM Clutch
« Reply #1 on: February 20, 2017, 06:16:19 pm »
Are they heavy-duty clutch springs? Is the actuating lever on the engine placed 90 degrees to the cable pull?
Offline steve7406
Re: RM Clutch
« Reply #2 on: February 20, 2017, 06:34:45 pm »
Hi John std springs and yes actuating lever is at 90 deg
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Re: RM Clutch
« Reply #3 on: February 21, 2017, 06:31:27 am »
Does the clutch work? Check that first. Did you check the basket fingers for wear? Also what model RM?
Offline steve7406
Re: RM Clutch
« Reply #4 on: February 22, 2017, 08:54:37 am »
Hi Pokey the clutch worked but was a bit heavy clutch basket fingers or good.
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Re: RM Clutch
« Reply #5 on: February 22, 2017, 09:56:09 am »
could be 40 year old springs were softer than the new ones? or is it unreasonable difficult.
Re: RM Clutch
« Reply #6 on: February 22, 2017, 09:58:35 am »
Simple things and if its working and wear has been checked its outside of the case for the issue. If clutch is all good it will be cable and perch. Also check the cable routing and shout it a new ca le as the inner liner will be worn.
Offline steve7406
Re: RM Clutch
« Reply #7 on: February 22, 2017, 03:37:44 pm »
Pokey bike is rm250t 1980
clutch has always been stiff but now it seems to be a lot harder I also put a new cable on and I have checked its where it should be
Husky yes its unreasonably hard I've been told there is some internal clutch adjustment?
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Offline fred99999au
Re: RM Clutch
« Reply #8 on: February 22, 2017, 07:33:52 pm »
Was the new cable lubricated?
Offline Oldfart
Re: RM Clutch
« Reply #9 on: February 22, 2017, 09:03:49 pm »
They are a heavy clutch ...adjustment
Needs to set internal , by a lead screw that takes up the
Slack on thepush rod ....make sure the ball bearing is installed
Between both rods
Offline steve7406
Re: RM Clutch
« Reply #10 on: February 23, 2017, 06:23:07 pm »
 Fred cable was new didn't think it would need to be lubricated
Old fart I'll have another look at it over the weekend
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
