Author Topic: kx250 Bits needed  (Read 3802 times)
Offline rocketfrog
kx250 Bits needed
« on: February 16, 2017, 07:37:11 pm »
Can anyone help with an exhaust system, and radiator grilles/radiators and front number plate and mudguards for a 1990 KX250. Most 1990 to 1993 look like they will fit or could be made to fit.
Scraped, scratched or faded is OK.
Looking for good usable bits or parts which could be repaired within reason, ie exhaust with a few dings wont be a problem if you catch my drift.
Just want bush basher quality- closer to Ipswich, Qld the better.
Cheers Jason
Offline SUZUKI311
Re: kx250 Bits needed
« Reply #1 on: February 17, 2017, 08:37:07 am »
i may be able to help, i will find out and let you know.
Offline SUZUKI311
« Reply #2 on: February 19, 2017, 11:47:22 am »
i have tracked down a set of plastics for 90 model, a muffler, a 93 bitsa-frame forks shock, swingarm, linkages wheels, clutch cover and a few other bits if your interested
Offline rocketfrog
« Reply #3 on: February 19, 2017, 10:58:38 pm »
The muffler for the 1990 sounds good, front and back mudguards still needed. I scored some rad shrouds and a straight radiator but still need a radiator grille. Having issues with the master cylinder (front) so I might need a replacement if I cant get this one to bleed. I do need some small bits such as sub frame shouldered bolts (allen bolts) and the front brake line clamp which attaches at the base of the fork leg.,  The other bit I need is a filter cage, the one from the later model should fit. pm your phone number please, i can give you a ring tomorrow if that suits.
Cheers Jason
