Marketplace
Wanted
35mm Marzocchi triple clamps
Topic: 35mm Marzocchi triple clamps (Read 4616 times)
LWC82PE
Superstar
January 18, 2017, 11:00:28 pm »
I am looking for some 35mm Marzocchi triple clamps for leading axle forks from 76-77 era Euro bikes, Canam or aftermarket Jap fitment. Not 100% sure what I want/need exactly as I don’t know what is/was available, but I believe these all have 25mm offset which is fine and I prefer laid back bar mounts. Seems like the double pinch bolts only came in the 80’s? so I think they need to have only single 10mm? pinch bolts to be from 76-77 era. I am not really sure though. I think the ones I would need have ‘Marzocchi’ cast into the lower clamp and not the fork/wheel logo. I am not really sure what exact bikes would have the clamps I want yet so its making it hard trying to look for them.
Eldert
Novice
Re: 35mm Marzocchi triple clamps
January 19, 2017, 03:13:07 am »
Hi
i have a set 35 mm Marzocchi triples laying around from a KTM with a leading axle fork .
i will try to locate them and take some pictures and measuremends
parts are in the Netherlands tho .
Eldert
LWC82PE
Superstar
January 19, 2017, 09:16:01 am »
Thankyou that sounds good.
Tony.Brown
B-Grade
January 19, 2017, 07:41:38 pm »
Leith, as a last resort, check with VTR Vinduro, he "ahem" acquired some leading axle Marzocchi forks from me years ago, can't remember if there were triples though.
Tony.
LWC82PE
Superstar
Reply #4 on:
February 18, 2017, 06:16:39 pm »
Still looking for clamps
This type but without a lot of those extra holes drilled in them which i think were for Canams. The ones i have seen from KTM's did not have the holes.
Last Edit: February 18, 2017, 06:22:25 pm by LWC82PE
LWC82PE
Superstar
Reply #5 on:
February 22, 2017, 10:58:23 pm »
I found some triples at a Marzocchi specialist in UK so I got them but they are missing the handle bar half clamps. So i just need a pair of those now.
Marketplace
Wanted
