Author Topic: Will a Yamaha blaster cylinder fit IT200.  (Read 6028 times)
Offline ELC hunter
« on: January 18, 2017, 01:19:13 pm »
Hi has anyone try to fit a blaster cylinder to an IT200 if so what do you need to modify, I think the exhaust flange is like a dt200 or ty set up on the blaster but that should be no problem any hints welcome  Cheers ELC.
Offline twinrock
Re: Will a Yamaha blaster cylinder fit IT200.
« Reply #1 on: February 06, 2017, 12:08:56 pm »
No it will not fit..blaster has the same stud patern as a dt200l which is diffrent from it200 i compared them..also the it200 would make more power
Offline fred99999au
« Reply #2 on: February 07, 2017, 10:54:15 pm »
It begs the question: "Why do you arks twodogs?"
Offline ELC hunter
« Reply #3 on: February 08, 2017, 08:58:25 am »
we locked it up solid on the hard loop hill climb at CD last year and it time to get it going for this year, blaster cylinder was only $80 new so worth checking out.
« Reply #4 on: February 08, 2017, 12:50:18 pm »
get a different brand, easier to fix ;D ;D
