Author Topic: Mounting a Mikuni carb on my 75 KTM 250  (Read 16281 times)
Offline Tahitian_Red
  • Mugen ME480
« on: January 18, 2017, 04:33:14 am »
Anyone have problems making this conversion?  I will use a 34mm Mikuni and trim the intake manifold 15-20mm.  Any jetting specs?
Thanks!  :)
The "Factory Novice"
California, USA
Re: Mounting a Mikuni carb on my 75 KTM 250
« Reply #1 on: January 18, 2017, 05:42:11 pm »
I like the bings on mine , they take some sorting but once they are I like them.
Offline ozktm
« Reply #2 on: January 19, 2017, 02:30:34 pm »
Running a 36mm bing with new slide/needle/needle jet etc. 76 MC5 250 runs like a champion.
Regards,
Adrian Goold #101
Offline supermotomc
« Reply #3 on: January 20, 2017, 04:13:11 pm »
Bert! would say, why? are you fitting a car carburator to a ktm!!!
  • Mugen ME480
« Reply #4 on: January 21, 2017, 06:59:35 am »
OK.  What is the best place to find rebuild kits and new slides for a Bing 54?  :)
California, USA
Offline ozktm
« Reply #5 on: January 22, 2017, 03:18:47 pm »
At this stage it depends on the model Bing you are running.
A type 2 Bing 54 (eg 54/38/106 stamping etc, ~42mm dia slide, slide stamp  # 220 or 230 etc), Andre at Enduro Klassiker can sort you out.
If its the earlier type 1 (eg 2/36/102 stamping etc , ~40mm dia slide, slide stamp #1 or #2 etc), i am waiting on a reply from Andre for availability of parts through him for these. Else you can try Al Beuhner at pentonpartsusa.com
I am about to rebuild a type 1 for a guy, hence seeing if available from andre as i am after type 2 parts as well for myself.
Regards,
Adrian Goold #101
  • Mugen ME480
« Reply #6 on: January 24, 2017, 04:47:13 am »
It is a Type 1  :(   Will a Type 2 work on the '74-'76 KTM 250's?
California, USA
Offline Nebo
« Reply #7 on: January 25, 2017, 05:34:03 pm »
    Yes a Type 2 will work .    For example 54/36/123.  Maico carb.
    Slide 230, main 180/185, Pilot 65/70 .
Offline ozktm151
« Reply #8 on: January 26, 2017, 07:08:09 pm »
If you change types you will probably have to change the intake manifold. I have come across three types. A flush fit from carby to manifold (type 1 ?) ,a plastic sleeve between carby and manifold (MC5) and then the later rubber connection to the manifold.
