Author Topic: YZ ignition on an MX100?  (Read 2364 times)
Offline Tahitian_Red
  • Mugen ME480
« on: August 21, 2008, 09:53:42 am »
I would like to update the points ignition on my MX100B to a later model YZ electronic ignition.  has anyone done a conversion like this?
The "Factory Novice"
California, USA
Re: YZ ignition on an MX100?
« Reply #1 on: August 21, 2008, 11:14:56 am »
Yep. YZ125E onto DT125.
Bolts straight onto the 125. The only possible difference would be the 100 crank might have a smaller taper.
  • Mugen ME480
« Reply #2 on: August 21, 2008, 03:14:15 pm »
Thanks Nathan!
Did you see a performance gain?
California, USA
« Reply #3 on: August 21, 2008, 08:05:02 pm »
Duuno, as I never rode it with the points ignition. But it 'has to' be better than points - stronger spark, variable advance curve, and a much lighter flywheel.
It did go a lot better than I expected, if that means anything.
With a YZ ignition, YZ piston, YZ carb, but otherwise 100% standard engine (including pipe) - good enough to put me solidly into the midpack of the pre-78 125 class at club level, and comfortably not last in the pre-75 class at the Nationals.
