Author Topic: CR125M stator cover  (Read 6696 times)
090
CR125M stator cover
« on: August 28, 2007, 09:16:24 pm »
Between one '74, two '75's and three motors,there is not one set of cases or one stator cover that wasn't smashed to bits. Obviously it is a common problem, what i want to know is it just a maintenance issue, or is it a design fault that has a cure? I just acquired an intact sidecover, but i don't want to put it on until i am reasonably sure it wont get smashed to smithereens
Offline Noel
Re: CR125M stator cover
« Reply #1 on: August 29, 2007, 08:33:13 am »
Yep common fault right through to 77
my bike came intact but was warned of problems,
so I put on extra chain guides and a roller mounted to the side stand bracket
will post pictures to night.
Noel
Quicksilver
« Reply #2 on: August 29, 2007, 10:39:19 am »
My first 1974 CR125m i had in late 1970s was gone their 090. So had most others around at that time. Soon as chain derails or breaks side cover takes a hit. Bikes that have that area intact were those that were maintained and looked after or had little use.
Offline Noel
« Reply #3 on: August 29, 2007, 10:33:53 pm »
Here are some pictures,
also planned to put a top guide case saver above chain off rear engine mounts
 but haven't got around to that yet
VCheers
Noel
Note to self (clean the chain before next meeting)
« Last Edit: August 29, 2007, 10:35:44 pm by Noel »
090
« Reply #4 on: August 30, 2007, 06:37:02 pm »
Thanks for the pic's Noel. I shall do the same mod on the '74 and '77. Cheers,Brad
