Author Topic: RM125b bottom end  (Read 2502 times)
Offline craigclayton
RM125b bottom end
« on: December 27, 2016, 06:23:18 pm »
Merry Christmas all, I am looking for a good usable bottom end, I have damaged the end of my crank trying to remove the stator( which is still not removed).  I'm so frustrated at myself for damaging the crank end, should have given it to some one that knows what they are doing:((
74 Bultaco 250, 77 RM125b
Re: RM125b bottom end
« Reply #1 on: December 27, 2016, 07:24:53 pm »
I probably have a usable crankshaft or when you get the flywheel off you could cut the external thread off (presuming that's what you've damaged), drill & tap the crank post & make it an internal thread. It's relatively easy to do & may save you a lot of heartache.
« Reply #2 on: December 27, 2016, 08:34:30 pm »
Thanks K will keep posting update as to extent of damage when(and if )rotar is removed
Cheers C
