Author Topic: For sale, '84 KX125 disc front-end.  (Read 2336 times)
« on: December 19, 2016, 07:43:18 pm »
'84 KX125 complete disc brake front end.  Also comes with an '84 TT600 top triple-clamp (vertical, rubber bar mounts)'
The following only 2 rides old from brand new.
* 20wt fork oil.
* Fork seals.
* Fork wipers.
* Headstem bearings.
* Front brake lever.
* Brake pads.
* 2 x cable guides.
* Wheel bearings & seal.
Dunlop MX51 - raceable.
CR500RE fork springs (only .36kg).
The air-valves have been cut off the fork-caps so I could slide the forks further up when running the TT600 top triple, you'll need to refit some air-valves if you want to run the CR springs, or get some .44kg springs.
Includes front guard (looks good enough to leave on a clean racebike) but it needs the collars for the 4 mounting screws.
There is a small amount of corrosion between the top & bottom triple; seal run area perfect.
$400
*** Pics to come shortly ***
Re: For sale, '84 KX125 disc front-end.
« Reply #1 on: December 24, 2016, 12:00:47 pm »
Have pics ready to go, let me know your email address and can send them through  :-)
« Reply #2 on: December 28, 2016, 07:12:36 pm »
Sold pending payment & collection.
