Author Topic: PD Fork Valve question  (Read 2745 times)
Offline Wasp
  • Your Suspension Solution since 1989
    • Suspensionshop
« on: December 18, 2016, 12:08:33 pm »
The time has come again to make another series of PROMAX PD Fork Valves.http://store.suspensionshop.org/maico/mx/1970-1979/79-79-mc-250-pd-fork-valve.html That is also the time to tweak the drawings and make improvements, if needed. There are many out there globally and doing a good job already. I would welcome any CONSTRUCTIVE criticism or hints for improvements and changes from you, now, before the machining is done. The areas that can be changed (if needed), are:
•   Ports
•   Lift plate free bleed
•   Size in OD of main body
•   C of spring (at the moment we use 7N/mm and 12N /mm )
•   Materials used
Thank you
« Last Edit: December 18, 2016, 12:22:37 pm by Wasp »
VMX shocks , We don't just sell them - I design and produce them individually for you since 1989.
