Author Topic: And so it begins, My IT250H Build  (Read 23148 times)
0 Members and 7 Guests are viewing this topic.
Offline Trokel510
« on: December 16, 2016, 09:54:26 pm »
A while back I purchased this little project, not because i needed another bike but because I like IT's and it seemed like too good a deal to pass up.
 But unfortunately it has been sitting around ever since as I just haven't been able to source some of the parts i needed at the right price that is up until now as last weekend I picked up this one also.
So now with a bit of luck I hopefully have everything that I need. Currently I have stripped them both down to only a frame in order to compare the 2 and pick the best one then start the rebuild from there. So Will keep you updated on the progress with more Pics to come
85' Husky TE510, 83' XR250R, 76' DT400C, 81' XL500S, 85' XL250R, 80' XT250, 82' XT200.
Hmmm, What should I buy next?
In case you were wondering it was an 85' CR250R. Then a 76' DT250 and a 01' XR250 and it didn't stop there
Re: And so it begins, My IT250H Build
« Reply #1 on: December 17, 2016, 08:55:25 am »
away we go 8)
Offline chippy
  • how old is too old
« Reply #2 on: December 17, 2016, 12:28:38 pm »
Good luck with the restoration Troy. Looking forward to more pics.
                                               Cheers Chippy.
Offline Trokel510
« Reply #3 on: December 17, 2016, 07:29:40 pm »
                                               Cheers Chippy.
Thanks.
My intent is for this to become my main Vinduro bike for the 2017 season so it won't be a showroom resto but I am still planning on turning it into a good looking bike that will hopefully be reliable.
Have had a busy day working on the frame.
Both frames had problems. The one on the left had numerous cracks, holes drilled in it for some reason, a completely mangled rear loop and broken side stand mount. The one on the right had a bodged footpeg, a fair bit of surface rust and some repairs to the rear loop that were pretty rough but overall it was probably the better frame but for some reason I decided to fix the other one. Think I just felt like a challenge.
The white tape is marking all the spots that need repairs
The rear loop was un-salvageable so I cut it off and started making a new one which I fitted up over some steel dowel pins for strength before welding into position
And after welding up all the other bits I managed to get the first coat of epoxy enamel paint on this afternoon with the second coat to follow tomorrow. This evening seeing as the paint was dry enough I stuck the rear guard on to show how the rear loop came up.
« Last Edit: December 17, 2016, 07:36:16 pm by Trokel510 »
Offline chippy
« Reply #4 on: December 17, 2016, 10:22:42 pm »
Keep them coming Troy. Chris's fibreglass  doesn't happen any longer , so you will have to make do with what you have.
« Last Edit: December 18, 2016, 04:03:02 pm by chippy »
Offline Trokel510
« Reply #5 on: December 18, 2016, 09:20:55 am »
Fortunately the first bike came with a full set of brand new plastics and I have 3 tanks to choose from so it should scrub up pretty well. Still tossing up what front end to put on it as the first one came with a TT250 disk brake front end and the second looks like it has an IT490 front end with the dual action drum brake. So if anyone has any thoughts on which one to go with and why that would be appreciated.
« Reply #6 on: December 18, 2016, 11:04:41 am »
good stuff
« Reply #7 on: December 18, 2016, 12:54:19 pm »
go with drum then you can cross the border for a few events. the it dls is a pretty good drum brake
Offline Trokel510
« Reply #8 on: December 18, 2016, 04:55:44 pm »
I was thinking of trying to get to some veri events next year so does that mean I would have to stay with the drum to be eligible?
Offline kdx Geoff
« Reply #9 on: December 18, 2016, 05:13:06 pm »
Fit the disc if it stops better/ more reliably. I don't imagine anyone's going to throw you out over a disc on the front  :)
Offline Trokel510
« Reply #10 on: December 18, 2016, 05:40:25 pm »
Was just looking through my selection of front wheels and at this stage most of the drum brake ones aren't real flash so i think it will get the disk front end for the time being.
Offline Trokel510
« Reply #11 on: December 20, 2016, 09:25:43 pm »
I have decided that I will try and make this build thread as informative as possible in an effort to assist others who are new to this type of thing and are thinking of taking on a project. So even though this will seem like pretty standard stuff to many of us I still find that I can always learn new tricks and tips from what others do. So with the frame sorted my focus turned to the swing arm and wasn't that a challenge. During disassembly of both bikes i had to remove the swing arm and shock as a complete unit because i couldn't get the shock to swing arm mounting pin out while still in the bike. What I didn't realize was how hard it was still going to be once removed and with better access.  So with this in mind I can't stress enough the need for regular maintenance which means applying grease/ anti seize lubrication to all pivot pins as well as bolts that pass through any spacers as part of suspension pivots such as swing arm and linkage bolts and also axles for wheels etc. And note this doesn't just apply to old bikes as often this doesn't happen when new bikes are assembled so if ridden in harsh conditions they can suffer from the same problem even though they are only a few years old. I found this when I tried to remove a swing arm bolt on a 2 year old KLR650. So even though it was so young the bolt had already began to seize in place due to a lack of lubrication when assembled.
Anyway so here is how it went down -
The shock to swing arm pivot pin passes though 2 steel ferrules that are pressed into the alloy swing arm and this is where the problem lies as without any lubrication they rust together and create a very strong bond. On both I heated the alloy and ferrule with map gas to expand it and sprayed the pin with freeze release spray numerous times but it still took an awful lot of force to press the pin out and in both cases the outer ferrule came with it which I then had to remove separately in the press. Also I had to cut the end of one of the pins off as it had already been damaged by someone else trying to get it out.
Anyway here are some pics
Here is the swing arm and pin with ferule still attached.
And here is how the swing arm looks now.
For the finish on the swing arm I started off by trying to cleanup and restore the natural aluminum look but after much work with a wire brush on a drill and sanding with wet and dry I realised that I wasn't going to get the result that I wanted so i decided to paint it just like I have for all the steel ones that I have done. So after preparing it I painted it with a quality etch primer and then over coated with epoxy enamel.
« Last Edit: December 20, 2016, 10:02:17 pm by Trokel510 »
« Reply #12 on: December 21, 2016, 08:29:10 am »
poor maintenance the curse of the resto :( >:(
fortunately my huskys both had excellent first owners who greased everything (Phew) nothing beats sliding out a well greased swingarm bolt after 20 years or so....makes life very easy
Offline Trokel510
« Reply #13 on: December 21, 2016, 05:52:45 pm »
I was very fortunate in that regard with my Husky as well.
 A few years ago I did up a couple of old Yamaha AG200's that i bought as wrecks for next to nothing and some people I know couldn't understand why i was putting so much time into them but to me it was good practice.  Because they were so cheap I had nothing to loose and they made great platforms for fine tuning my repair skills particularly with how to deal with the problems that come from poor maintenance. I figured if things went wrong it was better to stuff up an AG200 instead of a more valuable bike and as it turns out they both came up really well so we used them to dink the kids around on before they started riding their own bikes then sold them for a profit.  :D
« Reply #14 on: December 21, 2016, 05:58:48 pm »
always pays to start with something like that, cant go wrong too much.... ::)
