Author Topic: Suzuki RM 125 B/C bearings  (Read 5275 times)
Offline huskibul
« on: December 05, 2016, 02:23:11 pm »
One for the RM guys -Are 125 b/c OEM (koyo ?) gearbox / main bearings & seals still available from suzuki  Australia or do i need to get them from a local bearing service (eg NTN etc) Cheers
Offline Oldfart
Re: Suzuki RM 125 B/C bearings
« Reply #1 on: December 05, 2016, 07:13:43 pm »
Buy the LHs and RHs crank seals from Suzuki ( still available and cheap )  the rest just buy NTN bearings C 3 type .
All the other seals can be procured from a Bearing supplier.
Check for bearing wear on mag side of crank, ie very loose fit on shaft, or flogged out bearing mount to case
Offline huskibul
« Reply #2 on: December 05, 2016, 09:00:43 pm »
Thanks oldfart ! So C3 for the mains but are C3 also required with 4 gearbox bearings ? cheers
Offline Oldfart
« Reply #3 on: December 05, 2016, 09:03:42 pm »
C3 bearing ....yes to all
