Author Topic: Whats everyones view on the Yz465h  (Read 50222 times)
Re: Whats everyones view on the Yz465h
« Reply #45 on: December 10, 2016, 05:19:20 pm »
Mick on the Maygo you forgot to mention the brake backing plates that just disintegrate sending their riders head first down the track. Or how good their ignition systems are. And what about the clutch if you dare use it more than once. Then theres the stock rear shocks that dont work. So basically you have a bike that don't start, don't stop and will throw you over the bars with no notice. I have never seen a Maico 490 win one race of any importance in 10 years. They won nothing when new and are still doing the same thing now
Ted you are correct about many of the Maico's short Cummings. Maybe at Classic dirt or similar I could take your 465 for a few laps to turn me? It must be said Ted that most of the mods you insists correctly so that the Maico's needs the 465 needs similar?
On the YZ yes the forks and brakes need little but everything else does.
The Kato needs maybe less than either of these two.
The forks are under sprung and over damped needs springs and valving.
The front brake needs allot of setup or swamped for a Yamaha.
The original Ohlins are fine after a bit of love.
Needs Kawasaki clutch plates and allot of setup for a good feel or after market mechanism.
Yamaha con rod changes the port timing and brings the 390 engine to life and is a easy buy/fit
More than likely after market ignition.
If you can find one an 81 model 125 tank for extra slim feel.
Never had case or frame problems, gear box normally not no issues. The original Bing works fine if you know how to tune them.
« Last Edit: December 10, 2016, 05:24:52 pm by Slakewell »
Offline NSR
  • Sunshine Coast
« Reply #46 on: December 11, 2016, 09:46:23 pm »
I'll just leave this here :P.
« Reply #47 on: December 11, 2016, 10:17:37 pm »
Offline geoff
« Reply #48 on: December 11, 2016, 10:23:41 pm »
The SWM is a bullet proof machine.. Just wish it was in my shed with the 370 enduro!
Offline KTM47
« Reply #49 on: December 12, 2016, 12:50:47 pm »
Wow we are talking about a forty year old bike.  How much have you spent on your pogo stick again?
1.  How many forty year old bikes still have the same ignition>
2.  Yes the magnesium front brake backing plate does corrode and disintegrate with time but all magnesium parts do.  That is why the MoMS allows replacement parts that have been improved for safety.  Also the CNC billet backing plates make the brake better.
3.  The clutch.  Right it is a 500 class bike you only need the clutch for taking off and stopping.  The power spread is so good you don't need to slip the clutch like a 125.
4.  Yes Maico haven't won any World Championships and only a few Australian Championships.  Trevor Flood bought a stock Maico 400 in 1976 and won the Australian Championship.  The facts are it is the riders who win not just the bikes.  The Japanese factories bought the best riders.
But really I don't care keep riding inferior bikes I don't mind. Also Ted are you racing at the next Conondale Classic?
« Last Edit: December 12, 2016, 12:54:15 pm by KTM47 »
MAICOS RULE DESPITE THE FOOLS
Offline scottm
« Reply #50 on: December 12, 2016, 09:22:56 pm »
                                                    1982.5 Husqvarna Silver Streak
                                        2015 Conondale Classic Twin Shock Challenge
                                           3 x 15 minute motos overall winner..........
                                      What happened to your YZEE Teddy Ten Wrinkles ?
pre 84 thank you very much
« Reply #51 on: December 17, 2016, 02:21:57 pm »
here is a magic 465...its yet to be a reality but the price is sensational. here is someone who up fronts the real cost of restoring bikes...
http://r.ebay.com/PePurF
Offline skypig
« Reply #52 on: December 17, 2016, 08:04:44 pm »
Just to help with the translation:
"Immaculately restored" means "looks perfect, from across the room." (Stripped threads everywhere. Air filter made from packing foam. Radiator held roughly in place with one incorrect, of three mounts. Wheels can't be tightened due stripped fork/chain adjusters)
Just my experience.
Offline YZ250H
  • Back in QLD Baby !
« Reply #53 on: December 21, 2016, 09:58:05 am »
Frame: Gusset frame and weld full width skid plate under frame rails. Fit oversized ( thicker alloy ) engine plates and oversized high tensile bolts. Fit way oversized head stay bracket. You will not break a head or barrel. You need to take the flex out of the frame.
I thought Gussets were only for Women's underwear Ted  :o :o :o :-*
My old frame is rusted out, so I've got another one on the go.  What material, where and how thick are these gussets ?  How substantial is the bash plate ?  Any other frame mods required before I blast and paint it and start putting it back together ?
Offline Ted
« Reply #54 on: December 21, 2016, 01:12:28 pm »
From memory 10mm alloy plate for head stay, 6mm alloy engine mount plates. Can't remember bolt sizes but if were 8mm they are now 10 and 10 are now 13. Bashplate is approx 3mm steel with holes throughout. Fit foam between plate and motor when riding. Weld 5mm plate vertically above swingarm bolt housing full width and cut out chain run.
81 YZ 465 H   77 RM 125 B
Offline YZ250H
« Reply #55 on: December 21, 2016, 01:45:42 pm »
Received and understood thanks.
You're a good egg.  I've always said that about you  ;D ;D ;D
Offline Paulos
« Reply #56 on: December 21, 2016, 05:07:50 pm »
Just make sure that none of these additions foul the gearshift lever, making you think you've only got 1st gear. Just a suggestion.
Offline Ted
« Reply #57 on: December 21, 2016, 05:59:27 pm »
Ha. I fixed that one for him years ago. He couldn't possibly make the same mistake again could he? But what would i know. Apparently i just pay someone to do everything
Offline Paulos
« Reply #58 on: December 21, 2016, 06:56:26 pm »
Apparently
Offline Woody
  • Heaven #70
« Reply #59 on: December 21, 2016, 07:51:13 pm »
post up some close up pics of the mods Mr Teddles  :D
WANTED
1988/89 125 - CR KX YZ
IT200 stuff
CR250RD parts
