Author Topic: 1980 YZ100G with IT175 barrel and DG head  (Read 4673 times)
Offline bruce g
« on: December 04, 2016, 12:54:50 pm »
Need a little help here fellows
have acquired a complete 1980 YZ100g off evil bay for 200.00 a while ago
is complete but poor condition and not running
have done a little research on fitting a IT175 barrel and a DG head that i have
seems to me it will fit as the base gaskets are the same and the stroke is the same
head studs and heads are different but that doesn't matter as i have the matching DG head for the 175
the exhaust port is in the same position so i think the exhaust should match up
my questions are which is the best piston to use a YZ type one with or without windows in the skirt?
want to use it for motocross so the barrel will be going to Dave at 2 stroke performance for some extra porting
not sure if the skirts are for low down enduro type work ?
has any body on the forum done this type of combo any input would be appreciated
thanks
Bruce
Re: 1980 YZ100G with IT175 barrel and DG head
« Reply #1 on: December 04, 2016, 01:24:32 pm »
an dt175 barrel will work with your 100 cases but it175 have different cases to suit the large transfer ports in the barrel and no the base gaskets arnt the same
« Reply #2 on: December 04, 2016, 03:05:40 pm »
Part # = 1W1-11351-00-00
Part Description = GASKET,CYLINDER - Replacement Number = 18G-11351-00-00 *
Model Count = 18
DT125E 1978 125 DT125 Dual Purpose
DT125G 1980 125 DT125 Dual Purpose
DT125H 1981 125 DT125 Dual Purpose
DT175E 1978 175 DT175 Dual Purpose
DT175H 1981 175 DT175 Dual Purpose
IT125G 1980 125 IT125 Dual-Purpose
IT125H 1981 125 IT125 Dual-Purpose
MX175F 1979 175 MX175 Off-Road
MX175G 1980 175 MX175 Off-Road
MX175H 1981 175 MX175 Off-Road
YT125G 1980 125 YT125 ATV
YT125H 1981 125 YT125 ATV
YT125J 1982 125 YT125 ATV
YT175J 1982 175 YT175 ATV
YT175K 1983 175 YT175 ATV
YZ100G 1980 100 YZ100 Competition Motocross
YZ100H 1981 100 YZ100 Competition Motocross
YZ125D 1977 125 YZ125 Competition Motocross
Part # = 1W2-11351-00-00
Part Description = GASKET,CYLINDER BASE - Replacement Number = 18L-11351-00-00 *
Model Count = 3
IT175D 1977 175 IT175 Dual-Purpose
IT175E 1978 175 IT175 Dual-Purpose
IT175F 1979 175 IT175 Dual-Purpose
Part # = 3R3-11351-00-00
Part Description = GASKET,CYLINDER - Replacement Number = 3R3-11351-01-00 *
Model Count = 3
IT175G 1980 175 IT175 Dual-Purpose
IT175H 1981 175 IT175 Dual-Purpose
YZ125G 1980 125 YZ125 Competition Motocross
Part # = 1W2-11181-00-00
Part Description = GASKET,CYLINDER HEAD
Model Count = 10
DT175F 1979 175 DT175 Dual Purpose
DT175G 1980 175 DT175 Dual Purpose
Part # = 3R6-11181-00-00
Model Count = 2
« Last Edit: December 04, 2016, 03:19:17 pm by LWC82PE »
Offline crossedup2
  • Never enough shed time.....
« Reply #3 on: December 04, 2016, 08:11:20 pm »
If You can find a piston for a YZ175C, that may do the job in an IT barrel. Ring pins are the only question I'd have ???
    1L8-11631-01-97    PISTON STD (Not Available)
   1L8-11635-01-00    PISTON 1 O/S 0.25 (Not Available)
   1L8-11638-01-00    PISTON 4 O/S 1.00 (Not Available)
   1L8-11637-01-00    PISTON 3 O/S 0.75 (Not Available)
   1L8-11636-01-00    PISTON 2 O/S 0.50 (Not Available)
[from the Yamaha parts site]
Peter B
