Author Topic: TM and RM air cleaner intake tubes  (Read 4673 times)
« on: December 04, 2016, 11:40:54 am »
What is the ID of each end of the following Suzuki air cleaner boot/connectors
Need to know if they will fit 58mm on 30-34 Mikunis plus what size the airbox end is.
They are pretty expensive so I don’t want to buy one just to measure it
Part # = 13881-41000
Part Description = TUBE,AIR CLEANER OUTLET
Model Count = 2
RM100A 1976 98 RM100 OFF ROAD
RM125-M 1975 123 RM125 OFF ROAD
Part # = 13881-30711
Model Count = 4
TM250J 1972 246 TM250 CHAMPION OFF ROAD
TM250K 1973 246 TM250 CHAMPION OFF ROAD
TM250L 1974 246 TM250 CHAMPION OFF ROAD
TM250M 1975 246 TM250 CHAMPION OFF ROAD
Ebay tells me the air box/large end on this one is 75mm. is that correct?
Part # = 13881-41301
Model Count = 7
PE175C 1978 172 PE175 DUAL PURPOSE
PE175N 1979 172 PE175 DUAL PURPOSE
RM100B 1977 98 RM100 OFF ROAD
RM100C 1978 98 RM100 OFF ROAD
RM125A 1976 123 RM125 OFF ROAD
RM125B 1977 123 RM125 OFF ROAD
RM125C 1978 123 RM125 OFF ROAD
Re: TM and RM air cleaner intake tubes
« Reply #1 on: December 04, 2016, 01:46:20 pm »
Model Count = 2
Model Count = 4
Model Count = 7
I can say yes the Airbox end/ Large is 75mm on the PE175C,N (out of all my RM's and PE's the PE175N is the only one stripped down enough to measure ) I came up with 76mm measuring the O.D of air box but the air box was still in the bike without the airfilter outlet
 to carby tube removed
« Reply #2 on: December 04, 2016, 03:20:31 pm »
Yeah it is normal for the airbox to be about a 1mm bigger than the rubber. So 75mm confirms that one ok. Thanks
Offline craigclayton
« Reply #3 on: December 04, 2016, 05:46:48 pm »
Just bought one for my 125b $20:60 from Mick Hone in Melbourne????????
74 Bultaco 250, 77 RM125b
« Reply #4 on: December 04, 2016, 06:18:03 pm »
Thats a good price if i need one. Not sure yet. TM250 or RM125m might be better dimensions for my use.
« Reply #5 on: December 05, 2016, 01:11:08 am »
what about the ts185 hop up kit intake tube as they used a 30mm carb
« Reply #6 on: December 05, 2016, 08:34:14 am »
Might be an option. Got a part number for it? Just want something that is also readily available too and so far the PE175 one looks like best option in that aspect, but i would prefer a bit smaller than 75mm on the air box side.
« Reply #7 on: December 05, 2016, 10:44:49 am »
I think you will find it will be less than 75mm they are always a stretch to get on despite the retaining lip on the air box (spigot) most of the time I have to heat up ( usually with hot water in a saucepan ) same carby end (but with heat gun on low) with some surface tension releasing agent (I just spray kero it helps get the bastard on and dries with no oily residue) Ive probably gone to far some times and should of bought a new one instead of tinkering, but no crack or splits just a bit hard and slightly shrunk LOL tight ass, I am
(don't worry I do buy new ones and don't use those old all hard and brittle one's)
« Reply #8 on: December 15, 2016, 02:04:38 am »
part no for the ts185 hop up kit air cleaner to carb pipe is 13881 29700, fits 71 to 74 models
