Author Topic: PE250B clutch  (Read 8118 times)
Offline brent j
PE250B clutch
« on: November 29, 2016, 08:47:07 pm »
The clutch in my bike has the usual fibre plates but then two steel plates and the rest alloy, is this normal or aftermarket.
The alloys are stuffed so I'd like to replace them with steel. A bit more flywheel effect would suit me
Brent
Offline mick25
  • Hunter valley NSW
Re: PE250B clutch
« Reply #1 on: November 29, 2016, 08:54:03 pm »
Hey brent
The guy I got the bike from for you did say the clutch was wrong some where a long the line .
I can't remember if I told you that or not ?
Offline brent j
Re: PE250B clutch
« Reply #2 on: November 29, 2016, 09:19:41 pm »
No problems Mick, My memory is worse than yours so you probably did tell me.....................
The bike is a great core to work from, most of the usually lost bits are there and there's no more required that I would expect from any 40 year old bike
I still owe you one
Re: PE250B clutch
« Reply #3 on: November 29, 2016, 09:27:33 pm »
Alloy plates were optional 'race parts' usually. At least in the T/X/Z
parts list  shows 2 driven plates. 4 of 1 type and 1 of another. (total 5)
Yeah just checked
you probably have this which is aluminium
Part # = 21451-40001
Part Description = PLATE,CLUTCH DRIVEN
Model Count = 26
PE250B 1977 246 PE250 DUAL PURPOSE
PE250C 1978 246 PE250 DUAL PURPOSE
PE250N 1979 246 PE250 DUAL PURPOSE
PE250T 1980 246 PE250 DUAL PURPOSE
PE250X 1981 246 PE250 DUAL PURPOSE
RM250A 1976 246 RM250 OFF ROAD
RM250B 1977 246 RM250 OFF ROAD
RM250C 1978 246 RM250 OFF ROAD
RM250C2 1978 1/2 246 RM250 OFF ROAD
RM250D 1983 246 RM250 OFF ROAD
RM250E 1984 246 RM250 OFF ROAD
RM250F 1985 246 RM250 OFF ROAD
RM250G 1986 246 RM250 OFF ROAD
RM250H 1987 246 RM250 OFF ROAD
RM250J 1988 246 RM250 OFF ROAD
RM250-N 1979 246 RM250 OFF ROAD
RM250-T 1980 246 RM250 OFF ROAD
RM250-X 1981 246 RM250 OFF ROAD
RM250Z 1982 246 RM250 OFF ROAD
RM370A 1976 372 RM370 OFF ROAD
RM370B 1977 372 RM370 OFF ROAD
RM400C 1978 402 RM400 OFF ROAD
RM400N 1979 417 RM400 OFF ROAD
RM400T 1980 417 RM400 OFF ROAD
RS250T 1980 250 RS250 DUAL SPORT
RS250X 1981 250 RS250 DUAL SPORT
Alpha says 4 of those are std but my printed parts book says the  qty 4 plates is  this
Part # = 21451-40000
Model Count = 6
If you did happen to want Alloy plates, Barnett do them but they are 'cryodized' and ment to be a lot better than the plain OEM alloy plates. Lighter weight but more durable.
« Last Edit: November 29, 2016, 09:37:59 pm by LWC82PE »
Offline Terrapista
Re: PE250B clutch
« Reply #4 on: November 30, 2016, 06:20:24 am »
I put Barnett plates, aftermarket fibre plates and springs from Brintech. Does it matter if everything is not same or recommended that all parts are from one manufacturer
Leon
Offline Terrapista
Re: PE250B clutch
« Reply #5 on: November 30, 2016, 06:23:55 am »
Ferodo springs from Brintech that is
Offline gwc162
    • WayCool VMX Racing
Re: PE250B clutch
« Reply #6 on: December 01, 2016, 08:48:35 am »
My PE C had alloy plates and RM D steel so I used steel in the PE Barnett for plates an springs
Geoff
Suzuki RM250d, PE 250 c, WRf250, Multistrada 1000s
Heaven #162
Re: PE250B clutch
« Reply #7 on: December 01, 2016, 04:50:21 pm »
I just use steel, the oil stays a lot cleaner, make sure the free lengths are in tolerance and of course all the steel and fibre plates are also in serviceable tolerance, havnt found the need for harder springs in a 250 ( so far no clutch slipping or grabbing) as long as the fingers arnt to worn should be good to go
Offline Jumbo J
Re: PE250B clutch
« Reply #8 on: February 05, 2017, 11:20:52 am »
Is there a service limit for the springs, i could find one in my RM370 manual (i know this tread is for a PE)
Re: PE250B clutch
« Reply #9 on: February 05, 2017, 12:58:06 pm »
40.5mm std 38.5mm limit for PE250
