Author Topic: The next Suzuki PE250B question  (Read 4070 times)
Offline brent j
« on: November 27, 2016, 06:34:12 pm »
The next 250 B question. The headlight mounts, they have ears that hold the headlight. The ears are not in the centre between the triple clamps. Do they go above or below centre?
There's also a tab on one side that may hold a cable or wire, mine is broken but what side does this go on? My bike has the headlight mounted low, below centre, and the tab on the right.
What say you all?
Re: The next Suzuki PE250B question
« Reply #1 on: November 27, 2016, 06:47:26 pm »
Above center. Its all about aesthetics and what is pleasing  to the eye  ;) This would put the tab on the left i think? You can only put them on one way so as long as you have them above center then this will put the tab on the correct side anyway.
Offline brent j
« Reply #2 on: November 27, 2016, 06:52:35 pm »
Is the tab for the speedo cable? Just a thought
« Reply #3 on: November 27, 2016, 07:10:36 pm »
I can't remember. I will have to look at my brackets to jog my memory.
