Author Topic: PE250B seat brackets  (Read 5037 times)
Offline brent j
« on: November 04, 2016, 08:53:07 pm »
Is there any chance some one can post a photo of the brackets on a PE250B seat please?
I have a seat base but need to make some brackets. I have a later model seat that doesn't fit but I may be able to use the brackets
Thanks for any help
Brent
Offline frostype400
Re: PE250B seat brackets
« Reply #1 on: November 05, 2016, 05:40:11 pm »
I think I might have one in my shed I will look tomorrow and take a photo if I do.
1971 tm400 and PE's
Offline brent j
« Reply #2 on: November 05, 2016, 07:15:37 pm »
Thanks Frosty,
Could you also get a piccie of the seat rails to the back of the frame? Mine rises up from where the top shock mount brace meets the seat rail.
Not sure it this is right or it's been bent at some stage. The rear guard seems to sit a bit high
Offline frostype400
« Reply #3 on: November 05, 2016, 08:08:22 pm »
No worries will get a pic definitely have a couple 250b frames.
1971 tm400 and PE's
Offline frostype400
« Reply #4 on: November 06, 2016, 10:55:17 pm »
Both my 250b frames the rails are fairly straight so yours may be bent but as you can see my two look like they might have had abuse too google images they all look pretty straight.
My 250b seat has been modded the brackets lengthened had a  too they must have had a aftermarket tank here's a seat original so one side should have a hook and one side a hole I have a 175n plastic base on one with modded brackets
I have another 250b frame I forgot to check too
heres a 250b seat all orig
http://www.ebay.com/itm/171989342343
1971 tm400 and PE's
Offline frostype400
« Reply #5 on: November 06, 2016, 11:08:21 pm »
1971 tm400 and PE's
Offline brent j
« Reply #6 on: November 07, 2016, 08:32:39 pm »
Thanks Frosty,
I'll weld up the frame and straighten the rails. I have an aftermarket plastic seat base so I'll make some brackets to suit.
At least now I know how the frame should be
Brent
