Author Topic: KX125 1985 idle??  (Read 34831 times)
Offline 1983_Enduro_YAMI
KX125 1985 idle??
« on: October 22, 2016, 08:42:16 pm »
G'day all,
I'm new into the 125 two screamers.....dunno much about them....I've got myself a 1985 KX125 and spent a bit of money to get it to run like it should....just finish the tuning of the carby but there is one thing i'm not sure. What's the best rpm for the 125's to idle??? i watched a few clips and they're all idling higher than the 250/500..... ??? ???
Jacky
Re: KX125 1985 idle??
« Reply #1 on: October 22, 2016, 09:38:19 pm »
Don't overthink it. Get the jetting right, and then set the idle so it idles reliably for 30 seconds when the motor is warm. Then go riding.
« Reply #2 on: October 22, 2016, 10:08:52 pm »
So you mean set the idle so it idles 30 secs and dies if i don't blip the throttle??
« Reply #3 on: October 23, 2016, 02:28:17 pm »
if you cant open the gate and get back on the bike in 30 secs.....
« Reply #4 on: October 23, 2016, 02:51:44 pm »
Idle is a personal preference, as long as everything else is set correct (jetting, air screw) then it's up to you. Being a 125, go for 12000 rpm, that way you'll never be able to back off....
Offline Paulos
« Reply #5 on: October 23, 2016, 03:57:27 pm »
Senor Vandy was of the opinion,and i agree,  that you should set the idle high on a 125 so you're carrying revs a bit more in corners. Its not like you're producing cr500 type horsepower on idle
« Reply #6 on: October 24, 2016, 10:22:09 am »
What 85 Husky said about the thirty seconds.
Big or small, race bikes aren't meant to idle away forever - but you want them to idle for a bit so that you can put your goggles on or whatever. My point was more about you shouldn't get upset if it stalls after idling for minutes.
I sort of agree with the Vandy/Paulos train of thought, that a high idle can make a 125 easier to ride in some situations. But it can also make the bike hard to start, and just generally find it irritating.
« Reply #7 on: October 26, 2016, 05:22:06 pm »
I have the idle spot on now  ;).....but here comes another problem....i recently just reaplaced the old oval carby with a new round slide and i'm doing the mid range....It's paint in the arse....i'm stuck on getting the needle right. She's sputtering with the clip at the middle position so i moved up one notch and she's too lean....what should i do???
« Reply #8 on: October 26, 2016, 05:39:10 pm »
what mix you using?. you may need to look at another needle and needlejet combo
« Reply #9 on: October 26, 2016, 06:23:56 pm »
Possibly keep the needle in the middle spot & try the next size leaner needle jet or go leaner on the needle & richer on the needle jet. Not the most expensive part to replace, certainly quite a lot cheaper than changing the slide for example
« Reply #10 on: October 26, 2016, 09:07:59 pm »
I'm using 32:1 semi synthetic....i just put a 2.5 cutaway slide in and she runs heaps better....now it's just the mid range with the needle and needle jet.....I didn't touch the needle because i'm not sure of what's the next size down/up of 6FL52 (stock needle).....i did try to put a leaner needle jet (Q-6) but it seems a bit too lean for her as it was bogging down...I'm located at Western Sydney
Here is my jetting at the moment
Slide: 2.5
Pilot jet: 27.5
Needle Jet:Q-8 (standard)
Needle: 6FL52-2
Main jet: 290
« Reply #11 on: October 28, 2016, 10:39:44 am »
Depending on how lean it is with the needle dropped a clip position, it is possible to get shims that are half a clip thickness.
« Reply #12 on: October 28, 2016, 09:27:39 pm »
something else can't be right if it's going from spluttering (rich) to bogging (lean) in one clip movement..
« Reply #13 on: October 28, 2016, 09:54:31 pm »
Just a few question here with the 80's KX125's......when i quickly open half of the throttle from idle....how it should sounds normally??? Will the power valve opens up when i snap open half of the throttle?? It sounds pretty crisp but it's not bogging or gurgling when i dropped the needle....still smokin out when i went for a test ride
« Reply #14 on: October 28, 2016, 10:28:27 pm »
your at that point where its tough to diagnose by keystrokes...keep talkin :D
