Author Topic: Metal grade of Engine Mounting Bolts  (Read 14879 times)
Offline HL500
« on: October 16, 2016, 11:38:35 am »
I've seen some restored bikes with stainless engine mounting bolts.  These are low grade as far as I am aware.  Do mounting bolts need to be high grade or are mild steel bolts ok for this purpose?
Re: Metal grade of Engine Mounting Bolts
« Reply #1 on: October 16, 2016, 03:03:25 pm »
I dont like using high tensile bolts for engines. They snap were a low tensile bolt will stretch.
Offline PEZBerq
  • Brisbane
« Reply #2 on: October 16, 2016, 03:03:56 pm »
Best stick with 10.9 grade high tensile in my experience. I have stretched the threads of 8.8 grade engine mount bolts torquing up to Husky spec and had to cut the bolt to get it apart as the nut would not come off. Very annoying  >:( Never snapped one by torquing to spec.
Offline tymes
« Reply #3 on: October 16, 2016, 05:24:18 pm »
Ive never snaped an original factary engine bold nor a stainles one. But if you use stainless its a realy good idea to use thread lubricant or they tend to bind the treads.
« Reply #4 on: October 16, 2016, 07:29:00 pm »
if using s/s bolts and nuts must use different grade bolt and nut otherwise they will bind severely.
« Reply #5 on: October 16, 2016, 09:37:50 pm »
The stainless bolts I buy from the local bolt place behave something like an 8.8 or maybe a 10.9 - I wouldn't rate them as "low quality".
Offline yamaico
« Reply #6 on: October 16, 2016, 11:14:24 pm »
Your bolt guy is telling you porkies Nathan. Even the best stainless bolts have a tensile strength below that of a grade 5 bolt. I did a lot of research on this as part of a problem with bolts shearing in a saltwater application.
Edit: Unless he's selling you Bumax 109's, which are not common and quite expensive. Most bolt shops just sell the garden variety 304/316 bolts.
« Last Edit: October 16, 2016, 11:25:43 pm by yamaico »
« Reply #7 on: October 19, 2016, 10:59:59 pm »
Stainless has some strange attributes.
It will appear hard if trying to cut it with a hacksaw but it is a soft material.
I like the button head Allen head screws for their sleek look but this style has a shallow hex indentation and will chew out easily when doing them up.
« Reply #8 on: October 20, 2016, 08:54:19 am »
Stainless is for boats and Harleys.
Offline jimson
  • Sanctuary point N.S.W
« Reply #9 on: October 24, 2016, 10:49:33 pm »
My ex wife is stainless, she thought she looked good, but always broke under pressure lol jimson
« Reply #10 on: October 25, 2016, 07:50:30 am »
lol
