Author Topic: Replacement front fork Seals??  (Read 3276 times)
Offline BultacoMacca
« on: August 16, 2008, 10:18:01 pm »
Can anyone tell me if they have found replacement front fork seals to suit Bultaco Betor or Marzocchi shockies (35mm/47mm/7-10mm).
I can get four cheap bearing shop seals for $28(which don’t work for too long ie: they leak), or, good replacements at $52 for a set of four.
Are there any other options?
Offline jhovel
  • Joe near Bendigo
Re: Replacement front fork Seals??
« Reply #1 on: August 16, 2008, 11:11:28 pm »
Have you had a look at http://www.pyramid-parts.com/ specifically:
http://www.pyramid-parts.com/bultaco-35x47x105-fork-oil-seals-p-6440.html?osCsid=pcffd074j4htnetcirsvkim91hhguahf that's the right Bultaco seal.
They post to Australia in about 6 days flat and the postage is - from memory - GBP 3.95
Joe
Joe near Bendigo
SL175, SL70, XL250S, CT110 collecting bits....
Offline facthunt
« Reply #2 on: August 16, 2008, 11:41:35 pm »
Try KTM 65 seals.
Offline NSR
  • Sunshine Coast
« Reply #3 on: August 17, 2008, 10:07:41 pm »
I need to replace the the seals on my SWM,  facthunt have you used KTM65 seals in Marzocchi forks?
Noel
The Swvm though the tree's! http://youtu.be/4h6BbasT16I
Metalink Conondale vinduro sprint. May 19/20 2018
www.metalink.net.au  Bike trailers & Canopies
Offline facthunt
« Reply #4 on: August 18, 2008, 12:12:07 am »
Used them in Ceriani/Betors, non genuine, ARI I think.
