Author Topic: 1989 YZ250 Rear Brake Return Spring  (Read 6153 times)
Offline badbowie
« on: September 30, 2016, 04:34:19 pm »
Hi Guys,
Trying to locate the hole in my freshly powdercoated frame where the rear brake return spring mounts to.
Short of removing all the paint I was hoping someone may be able to provide a photo of a similar year/model yamaha to give me a bit of an idea where to start digging with the scriber.
Thanks is advance.
Offline rocketfrog
Re: 1989 YZ250 Rear Brake Return Spring
« Reply #1 on: October 26, 2016, 12:53:23 pm »
next to the swing arm pivot bolt there is a tag with a hole in it.
Offline badbowie
« Reply #2 on: October 28, 2016, 11:34:04 pm »
Thanks it looks like that tag has been broken off on my bike.
Offline smed
« Reply #3 on: October 29, 2016, 08:23:58 am »
You can drill a small hole in the approx position you think it should be in the frame where the swingarm bolt seats on the lower flat edge, some bikes are like that from factory, I have a 93 RM125 like that, or try one of these, dunno if only Hammerhead do em or others also ;)  https://www.google.com.au/search?q=Hammerhead+brake+spring&biw=1920&bih=989&espv=2&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjL6JKht_7PAhWCKZQKHdlXAl4QsAQIGg
Offline badbowie
« Reply #4 on: October 29, 2016, 10:17:59 pm »
I'm thinking along the same lines of drilling a small hole in the frame, my alloy frame WR450's brake return spring attaches to a small hole in the frame near the swingarm pivot bolt. I'm thinking something the same as it.
