Author Topic: Wrecking YZ250H. All sold.  (Read 33067 times)
« on: September 15, 2016, 06:01:06 pm »
Or maybe a big project for someone with a lot of enthusiasm...
Bike is very ugly, but matching numbers and pretty much all there.
Main things missing are seat, side covers, and ignition coil.
1. Motor. Turns over with very noisy main bearings.
LHS case has a putty repair at front of ignition housing. No damage near the sprocket. No broken/noticably bent fins on head/barrel.
Sprocket cover is there. Ignition cover is not.
Gear lever & kickstarter both there, not welded. $250. On hold.
2. Carby. $50
3. Pipe. Ugly and has bodgy replacement header. Crappy aftermarket muffler included. $5
4. Ignition. No coil. Original stator has wires cut. No idea why. Supposedly good replacement stator , CDI box and extra flywheel included. $100.
5. Forks. 43mm, angled lug type. Pretty sure they're the correct YZ-H forks (despite what I said earlier...) Axle threads in on LHS leg, two 8mm pinch bolts on RHS, one bolt for cable clamp on LHS. Some rust between triples on one leg only. SOLD.
6. Front brake. SINGLE LEADER, NOT TLS. $25 SOLD.
7. Front wheel no significant/noticeable cracks or flat spots. Flat style rim, and 83 type hub, presumably IT. Rim is date stamped 1/83. Spokes rusty but serviceable. $40
8. Rear wheel stamped 12/80. No noticeable cracks or flat spots. Spokes rusty but serviceable. $50 SOLD
9. Triples. YZ-H type with swept back bar mounts. Sexy blue paint... Seem good. $25. SOLD
10. Tank is buggered, but tap, cap and mounts available. $15/lot.
11. Airbox with filter cage. $30 SOLD
12. Swingarm. No obvious chain rash, except some on the inside next to the rear sprocket (you have to look for it) . Slider still present and intact. $40
13. Frame. Ugly. Has repair to rear (near seat mount on LHS). $40 SOLD
14. Front guard has been chewed by a dog, rear guard is some cheap crap (also chewed by dog), front number plate is crappy. $Free.
15.  Footpegs, rear brake stay, brake rod etc, just ask.
Located in Yass NSW, can deliver to Melbourne TOMORROW (sorry for short notice).
I have photos on my phone that I can SMS to anyone who is interested.
Nathan. 0400023847
[/sold]
« Last Edit: September 27, 2016, 08:50:28 pm by Nathan S »
Offline Krikey
Re: Wrecking YZ250H.
« Reply #1 on: September 17, 2016, 01:06:23 am »
Hi Nathan. I'll take the fuel tank please. Thanks.  Send me a PM and I'll respond. Cheers
Offline pinned
« Reply #2 on: September 17, 2016, 02:40:45 am »
I will take the triple clamps mate, will you post to Brisbane?
« Reply #3 on: September 17, 2016, 09:27:51 am »
No problem.
I'll get a quote later today, but it will be around $15~20 for postage.
« Reply #4 on: September 17, 2016, 09:46:36 am »
Edit original post with some more details.
The motor free'd up with some petrol poured into it. Main bearings are very stiff/grunchy. My vibe is that it would run, but I would STRONGLY recommend rebuilding it...
Offline Wasp
  • Your Suspension Solution since 1989
    • Suspensionshop
« Reply #5 on: September 17, 2016, 09:50:07 am »
Nathan , I would like the forks , rear and front backing plates  , frame and swing arm please .
VMX shocks , We don't just sell them - I design and produce them individually for you since 1989.
Offline Wasp
    • Suspensionshop
« Reply #6 on: September 17, 2016, 11:00:57 am »
Nathan , if the airbox and filter cage are still there , I will gladly take that as well .
« Reply #7 on: September 17, 2016, 11:24:32 am »
No worries Walter. What do you want to do about freight?
Offline Wasp
    • Suspensionshop
« Reply #8 on: September 17, 2016, 11:43:07 am »
I can pay for now , thats not a problem . Just waiting for my daughters march out date at ADFA , then I will cruise through Yass . Would that be OK ?
« Reply #9 on: September 17, 2016, 01:54:53 pm »
That will be fine, providing it is in the next month or two.
Offline Wasp
    • Suspensionshop
« Reply #10 on: September 17, 2016, 03:14:24 pm »
I think its end of November  or first week December . Otherwise , can you dropped it of in Melbourne . Mark from MRT will gladly bring it to Adelaide for me .
« Reply #11 on: September 17, 2016, 03:36:14 pm »
December is fine.
I'll PM my account details.
Offline Wasp
    • Suspensionshop
« Reply #12 on: September 17, 2016, 03:52:41 pm »
Please ad the brake pedal to my invoice as well .
Offline Wasp
    • Suspensionshop
« Reply #13 on: September 18, 2016, 10:30:38 am »
Paypal done .
Offline pinned
« Reply #14 on: September 18, 2016, 03:32:28 pm »
Pm sent Nathan.
