Clubroom
Tech Talk
XR250 sprockets.
Topic: XR250 sprockets. (Read 6621 times)
Nathan S
Superstar
HEAVEN #818
XR250 sprockets.
August 18, 2016, 07:11:33 pm »
Can anyone confirm that the rear sprockets are different between the 86-89 (drum brake) uses a different rear sprocket to the 90-94 (rear disc) models?
Mick D
Re: XR250 sprockets.
August 18, 2016, 08:09:15 pm »
I think they are different Nathan, but I will check.
They certainly are different drum and disc on the bigger capacity XRs.
What is the ID? PCD? #of holes, and amount of teeth you are looking for? I have more than a hundred New ones
"light weight, and it works great"
Nathan S
Superstar
HEAVEN #818
August 18, 2016, 08:14:27 pm »
Short version of a long story:
I need one front sprocket and a rear sprocket for both an 89 and a 91.
13/48 is standard, so something close to that.
I'll get PCD and ID measurements tomorrow.
smed
August 19, 2016, 10:42:21 am »
My Link parts book says they are different,according to this book the 90-94 uses the same rear as 84 on CR's
, different gearing of course
Clubroom
Tech Talk
XR250 sprockets.
