Author Topic: dr 350 sn - 1992 front master cyl needed  (Read 3947 times)
« on: August 15, 2016, 06:11:20 pm »
so im pulling the front brake to bits to find its seized cos the piston is welded to the body and there is severe corrosion. need a nother master cyl. any sort will do as long as it has a brake switch and takes the 8mm? union..(12mm hex head)
its a nissin master but 240 bucks at your suzook dealer :o :-\
Re: dr 350 sn - 1992 front master cyl needed
« Reply #1 on: August 17, 2016, 07:45:46 pm »
got one....
