Author Topic: front end conversion  (Read 7464 times)
Offline 777klx
« on: August 11, 2016, 07:27:32 am »
Reading the latest vmx magazine,I saw that a readers ride kx440 had a yz front end conversion and it made me wonder if it is very hard to do or if anyone has done this.
Offline William Doe
Re: front end conversion
« Reply #1 on: August 11, 2016, 08:41:08 am »
Its an easy conversion Josh , the twin leading Yamaha brake is hard to find .
It would be overkill on your KLX though . Fit some easy to get 38mm forks from a Yamaha and use the Yamaha SLS front brake , easy to get and way better than those shit Kawasaki front brakes  :)
Offline 777klx
« Reply #2 on: August 11, 2016, 10:50:11 am »
Thanks Bill,I've already got 2 twin leading wheels and a brake so just thought the 43mm be a good choice,what are the 38mm Yamaha forks off? Yz d-g?
« Reply #3 on: August 11, 2016, 01:33:55 pm »
38mm Yammie forks came on lots of things. IT175J/K, YZ250/400/465D~G, YZ125H~K, and at least some IT250/465 (not sure when the bigger ITs went to 38mm forks, but they were 43mm on the K model).
But be aware that they all have the angled lug for the backing plate, while most TLS backing plates are the horizontal lug type.
« Reply #4 on: August 11, 2016, 04:19:47 pm »
Be aware that Yamaha forks are short in overall length. Whilst the travel can be the same the overall is too short , for bikes like KTM and Huskies. It changes the angle to much.
« Reply #5 on: August 11, 2016, 05:20:08 pm »
Interesting!
In that case, YZ250/465G forks are the answer - they're stupidly long. I think IT250/465H/J are similar.
« Reply #6 on: August 11, 2016, 07:39:59 pm »
Whilst they appear long , on some models , do the math. Fitted a pair of 43 mm with twin shoe Yamaha to a 81 KTM 495 only to work out after a while why it sucked in the corners, re measured it all up and found it 20mm to low, Having said that I have YZ D forks in my 77 KTM with Yamaha front wheel. Just remember overall length is important.
