Author Topic: Calling 1983 XT550 gods  (Read 8145 times)
Offline cemotobull
« on: August 07, 2016, 06:55:10 pm »
Hey all,
We are helping a mate get his 1983 XT550 running.
Now here's the questions;
Do you need a battery to get spark on this model? (We have disconnected the lighting as there are no plans for rego). It doesn't have a spark with the battery connected.
Does anybody have a wiring diagram for ignition only?
Currently getting no spark, what are some of the simple fault finding exercises on this model? (Plenty of compression - no spark at all (not even a weak spark).
What is the best way to test the ignition??
Any other tips of suggestions welcome.
Thanks in advance!!!
Re: Calling 1983 XT550 gods
« Reply #1 on: August 07, 2016, 07:16:57 pm »
Check pulser coil and wires comming from it. Can be issues with them on those and the 600's. Coil falure and pinched/broken wires. Best way would be to follow test procedure in workshop manual.
« Reply #2 on: August 08, 2016, 07:41:11 am »
get ol mate to hold the spark plug wire while you kick it. that a 100% reliable method for testing spark
Offline mick25
  • Hunter valley NSW
« Reply #3 on: August 08, 2016, 12:30:16 pm »
 ;D my dad used me for that testing method at eight years old  :'(
I have been told it can put your heart out of ryhm  ???
Offline cemotobull
« Reply #4 on: August 08, 2016, 12:52:28 pm »
Lol, we did do the electrocution test, unfortunately with no result!!!
So who is XT Master of spark??
Offline mick25
  • Hunter valley NSW
« Reply #5 on: August 08, 2016, 01:44:58 pm »
I did have the same bike years back it went well.
 Yes it did run with no battery .
But I never had elec probs with it at the time .
Is the earth wire ok on the frame ?
I've had times when the spark plug cap has been pulled off over and over and the cap to coil lead is chewed out , I just cut 10mm off the coil lead and re fit cap sometimes its the little things .
That's about all my elec back ground  :o
« Last Edit: August 08, 2016, 01:48:04 pm by mick25 »
« Reply #6 on: August 08, 2016, 11:56:22 pm »
Hey all,
Check if the CDI is wired in after the rec/reg that means the CDI is drawing 12v from the charging circuit to work. If it bypasses the rec/reg it's probably a AC system and doesn't need the battery.
You and Yamaha sparks  :D :D :D
Offline OverTheHill
« Reply #7 on: August 09, 2016, 10:13:46 am »
been years but should just a std yamy cdi system for this type of 4 poke single, similar to tt250 etc. Guessing red/white from pulser to box. brown & a red from each end of the source couil [cdi charge coil] into the box. Orange from box to plug coil. I'm lost after that. Probably a black with white tracer to the kill swich/ign switch/stop button. any black left over would be an earth & might be a black from stator to go to earth--& or from the box, not sure. sorry if that just confuses the issue. Won't be battery powered anyway.
