Author Topic: New parts clean out  (Read 2791 times)
Offline SUZUKI311
New parts clean out
« on: July 29, 2016, 10:28:30 am »
1975-1977 CR/MR/MT250 piston kit .5 o/s $80, XL250 73-76 K series gasket set $40, CR500 piston kit up to 2001 std $140, XR250 piston kit 74mm $120, KX125 99/00 piston kit $90, XR80 piston kit all years $90, XR650L top end gasket set $20, CR125 03/04 top end gasket set $30, 1984/85 CR125 top end gasket set $30, 1992 KX250 gasket set $30, XR50 high comp oversize piston kit 52mm $70, 2004/05 KX125 gasket set $30, CRF150R top end gasket set $30, RMZ250 2007-2012 top end gasket set $$40, RMZ250 2007-2012 stainless valve set and springs to suit (inlet and exhaust) $150. All will be sent Aust post , and post cost is the responsibility of the purchaser. Any enquirers 0408571900 cheers Bill
Offline KB171
Re: New parts clean out
« Reply #1 on: July 29, 2016, 03:11:03 pm »
Pm sent re 1975-77 CR piston kit.
« Last Edit: July 29, 2016, 03:32:19 pm by KB171 »
