Author Topic: Wanted  (Read 2721 times)
Offline craigclayton
Wanted
« on: July 16, 2016, 06:22:38 pm »
Limited budget on the rebuild, looking for a usable rear wheel for an rm 125 b. Not sure if a ' c ' wheel is the same.
74 Bultaco 250, 77 RM125b
Re: Wanted
« Reply #1 on: July 16, 2016, 06:44:19 pm »
78 hub is different. TS185 uses the same wheel/hub as 125b except the rim is steel so there is plenty of easy options to get another hub but finding a good used alloy rim is a lot harder.
How good do you need the rim to be? I got one, no dents or cracks but needs a lot of sanding and work with a file on tyre lever marks etc. I think you could get it looking 'respectable' but if you want it better than that (which i did) then you will have to get a new or very low use rim. What i have would not be good enough for a top restoration.
« Last Edit: July 16, 2016, 06:50:49 pm by LWC82PE »
Re: Wanted
« Reply #2 on: July 17, 2016, 02:58:44 pm »
PM sent
