Author Topic: Mk6 Bultaco  (Read 13012 times)
Offline steve234
Mk6 Bultaco
« on: July 11, 2016, 12:31:34 pm »
Any mk6 pursangs out there? Looking for a 125 but will consider others.
Steve
Bultaco M106 Astro
Wanted: Dirt track bikes / parts / info
Re: Mk6 Bultaco
« Reply #1 on: July 12, 2016, 10:51:29 am »
What about a MK7 125?
Offline steve234
Re: Mk6 Bultaco
« Reply #2 on: July 12, 2016, 08:25:22 pm »
Bigk,
Pm sent.
Bultaco M106 Astro
Offline jas150
Re: Mk6 Bultaco
« Reply #3 on: September 16, 2016, 01:01:12 pm »
Are you still looking for a Pursang Mk6 125? I have one I am considering selling.
John
Offline steve234
Re: Mk6 Bultaco
« Reply #4 on: September 16, 2016, 05:16:00 pm »
G'day John, I did pick up a 125. A mk7 came up so I grabbed it. Soon as I did a number of bullies became available. Most I have seen at 1 time. The one I picked up looks good but really isn't. Send me a pm with some details and pictures if you have any.
Steve
Bultaco M106 Astro
Re: Mk6 Bultaco
« Reply #5 on: September 16, 2016, 05:56:40 pm »
FYI 250 head and barrel fit straight on, bottom end identical on 250 and 125 for MK 6 and MK 7 ( and maybe MK8 but I'm not 100% sure) just add 36 mm Mikuni and CDI for guaranteed happiness. Please note 360 conversion not an option. An option maybe? Cheers Jerry
Offline Daryl Jones
    • Old Bike World
Re: Mk6 Bultaco
« Reply #6 on: September 16, 2016, 10:39:43 pm »
Different balance factor between 125 crank & 250, big difference in piston weights.
Cheers, Daryl.
Life's too short not to try to do Everything.
"First they tell you you're wrong, and they can prove it.
Then they tell you you're right, but it's not important.
Then they tell you it is important, but they knew it all along."
Charles Kettering.
Re: Mk6 Bultaco
« Reply #7 on: September 16, 2016, 10:48:32 pm »
Aren't the cranks the same weight? J
Offline Moto
Re: Mk6 Bultaco
« Reply #8 on: September 17, 2016, 08:15:27 am »
There was a big difference in holes in the crank for different models.You can change the barrels as you say,but ideally change the crank.All the other bottom end parts are the same.Don't forget to change the timing and carb.
