Author Topic: xr 350  (Read 4747 times)
Offline Scuberdiver
xr 350
« on: July 10, 2016, 09:20:49 pm »
OK i have a xr 350 /83 motor has started to blow smoke since i droped it in  the creek at harrow last year and drowned it  got it  going and finished then got home drained the oil 8times  then it came good black again well bike sat for  8 month started 2 kick at idles no smoke as soon as you give it some throttle  shit loads of smoke  have entered this year harrow should i ride the bike keep a eye on oil levels top it up when needed or try and fix top end not much time
Offline Scuberdiver
Re: xr 350
« Reply #1 on: July 11, 2016, 05:50:04 pm »
all fixed put the 350 on the back burner got another xr to ride
Offline xl59
Re: xr 350
« Reply #2 on: July 12, 2016, 09:57:24 pm »
Check your breather tube on the 350 have had one blocked caused same problem ...
Offline Scuberdiver
Re: xr 350
« Reply #3 on: July 12, 2016, 10:45:37 pm »
  Will  have a look other than that the plan is a full rebuild  The breather tubes you mean the big gray ones will do thanks
« Last Edit: July 12, 2016, 10:47:38 pm by Scuberdiver »
Offline Scuberdiver
Re: xr 350
« Reply #4 on: July 16, 2016, 08:17:21 pm »
Checked the breather tubes not blocked so looks like a rebuild  thanks xl59
